23769 Discussions
Hello every pls help me fix this
Longdao2202
I already updated all graphic and disabled and enabled intel graphics adapter btw my laptop is msi mordern 15 A11MUimage.jpgimage.jpg
AlHill
What do you want fixed?  The message is self-explanatory.  Your system does not meet the requirements for the driver you are trying to install.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
AlHill
Longdao2202
Ok every i have a way to fix this but i don’t know how long it will be ok just can just install intel(r) graphics driver software and click to reboot,everything will be normal
