23768 Discussions
Help me install driver please
DLive1
System Information
Time of this report: 9/19/2015, 15:03:21
Machine name: ARABO-ПК
Operating System: Windows 7 Максимальная 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: Russian (Regional Setting: Russian)
System Manufacturer: Acer
System Model: E1-510
BIOS: InsydeH2O Version 05.03.47V2.11
Processor: Intel(R) Celeron(R) CPU N2820 @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 2048MB RAM
Available OS Memory: 1934MB RAM
Page File: 1699MB used, 2168MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Стандартный VGA графический адаптер
Manufacturer: (Стандартные мониторы)
Chip type: Intel(R) VLV Mobile/Desktop Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_08451025&REV_0C
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1366 x 768 (32 bit) (1Hz)
Monitor Name: Универсальный монитор PnP
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (Russian)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: Нет данных
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 03:25:51, 10752 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4C71-11CF-9433-F535A2C2CB35}
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x08451025
Revision ID: 0x000C
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Динамики (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0282&SUBSYS_10250845&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHDA.sys
Driver Version: 6.00.0001.7071 (English)
WHQL Logo'd: Yes
Date and Size: 10/22/2013 16:38:24, 2876760 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Микрофон (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Мышь
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Клавиатура
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 113.3 GB
Total Space: 129.9 GB
File System: NTFS
Model: ST500LT012-1DG142 ATA Device
Drive: 😧
Free Space: 334.5 GB
Total Space: 346.9 GB
File System: NTFS
Drive: E:
Model: HL-DT-ST DVDRAM GUA0N ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Russian), 11/21/2010 01:29:03, 108544 bytes
System Devices
Name: Qualcomm Atheros AR956x Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_0036&SUBSYS_064211AD&REV_01\4&1B886D26&0&00E1
Driver: n/a
Name: Стандартный VGA графический адаптер
Device ID: PCI\VEN_8086&DEV_0F31&SUBSYS_08451025&REV_0C\3&11583659&0&10
Driver: C:\Wind...
DLive1
Video card driver*
MJ2
Run the driver update utility which can be found here: http://www.intel.com/p/en_US/support/detect?iid=dc_iduu Intel® Driver Update Utility
This should detect and download the drivers that you need.
