23832 Discussions
Help please!
CMont6
good morning, I have come to present a problem and I hope you help me.
I have a problem called 'Can not find the name of Intel ICD OpenGL driver', in this problem it was recommended to update but due to certain circumstances I could not, those downloads are not compatible with my laptop, please help me, I've been looking for answers but none helps me
Characteristics:
Perceiver: Intel (R) Core (TM) i3-6100U CPU @ 2.30GHz 2.30 GHz
Memory (RAM): 8.00 GB
System type: 64 bits (Windows 10)
Stefan3D
Try drivers from this list: https://downloadcenter.intel.com/product/88355/Intel-HD-Graphics-520 Downloads for Intel® HD Graphics 520
If you encounter an error message about validation, then install driver via "have disk method" as described at:
www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
CMont6
Stefan3D I tried it with the last driver uploaded, but it tells me that the driver is not valid for this system, thanks anyway friend
Stefan3D
In the download list hit "show more", there are 8 different drivers available.
Regarding the validation, follow the aforementioned tutorial.
CMont6
@Thank you very much man, I solved it, thanks for answering my problema Stefan3D
