22862 Discussions
Help with changing settings of Intel HD Graphics 400 resolution
JohnSe
Bought a unknown Win 10 tablet with Intel HD Graphics 400.
Everything seems ok. Problems starts when I start installing games
Games installed ok but when run the game display on the lower half of screen in portrait mode
Its odd as I have run these games on another Win 10 with no problem.
Played around the resolution display but problem still exist.
First I look into the Control Panel and at Advanced Display settings
it shows
Desktop resolution 1920x1200
Active signal resolution 1200x1920
It seems odd to have such active signal resolution.
So I look into Intel HD Graphics Control Panel
Under Options and Support
- Under Information Center, I select Built-in Display under Select Option
I saw the Maximum Image Size
Horizontal Size 5.52 inches
Vertical Size 8.66 inches
Supported Modes
1200 x 1920
Clearly, the horizontal and vertical size settings are reversed.
I believed this should be cause of the problem of the games not running.
Is there a way to resolve this setting.
Any Advice.
Thank you in advance
LeonWaksman
Open Windows Settings > System > Display and change the Orientation as required.
Leon
JohnSe
Thanks for the reply.
I have tried this before. Changing the Orientation ONLY works in windows mode. It does not work for the games I am running in fullscreen mode.
But why is the active signal resolution and horizontal and vertical sizes reversed? This is not case for my other tablets?
Any way to edit the settings?
Just to add or clarify
I am able to run the game in potrait mode but not in landscape mode for fullscreen.
In landcaspe fullscreen the display is locked to the bottom of display with part of the graphics cropped.
In potrait fullscreen, the display is a small display at the center with big top and bottom black borders
DeancR_Intel
Hi JohnSe,
Thank you for posting in the Community!
I suggest the following steps:
Intel Graphics Control Panel:
  • Open the Intel Graphics Control Panel.
  • Go to Display > General Settings.
  • Ensure the Rotation setting is set to the correct orientation
Custom Resolution:
  • In the Intel Graphics Control Panel, try creating a custom resolution that matches your desired display settings. Go to Display > Custom Resolutions and set the resolution to 1920x1200 with the correct orientation.
Here's the link for your reference: How To Change My Display Resolution using Windows Display Settings or...
Dean R.
DeancR_Intel
Hi JohnSe,
Dean R.
DeancR_Intel
Hi JohnSe,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
