22973 Discussions
Hi I have 8 out of date drivers im unable to find the downloads currently
NicholasMoore87
 I tried to auto update with intel but it didnt show theses and my Norton driver updater says I have theses updates which I am unable to find any theses updates like the latest Realtek audio update i found was  6.0.9706 but in the norton window below it shows I need to update to  6.0.9724.1 also the others i need links for if could help me thanks
AlHill
Norton is not a very nice tool, is it?
Go to your system/motherboard manufacturer site and get the drivers from there for your motherboard.
Also, have you run the chipset device software for your board (also available from the manufacturer site).
And, stop using Norton.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
NicholasMoore87
ok yeah it had a free 60day norton driver updater i thought windows update did it all but guess not the norton driver updater didnt do anything so i guess you are right
LeonWaksman
You have not provided any information about your system.  In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
NicholasMoore87
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"11/08/2024"
Time:"00:00:15.3878934"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Alienware"
BIOS Mode:"UEFI"
BIOS Version/Date:"Alienware 1.20.0 , 05/29/2024 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"12th Gen Intel(R) Core(TM) i9-12900KF , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.4"
Sound Card:"NVIDIA Virtual Audio Device (Wave Extensible) (WDM)"
Sound Card:"NVIDIA High Definition Audio"
Sound Card:"USB Audio Device"
Sound Card:"Realtek Audio"
System Manufacturer:"Alienware"
System Model:"Alienware Aurora R13"
System SKU:"0AAB"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "NVIDIA GeForce RTX 3080 Ti"
Adapter Compatibility:"NVIDIA"
Adapter DAC Type:"Integrated RAMDAC"
Adapter RAM:"4.00 GB"
Bits Per Pixel:"32"
Caption:"NVIDIA GeForce RTX 3080 Ti"
CoInstallers:"oem148.inf,Section048,Integrated RAMDAC,NVIDIA GeForce RTX 3080 Ti"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"nvlddmkm.sys"
Driver Date:"10/14/2024 08:00 PM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\nvddi.inf_amd64_6b0ab0a43cab35f6\nvlddmkm.sys"
Driver Provider:"NVIDIA"
Driver Version:"32.0.15.6603"
INF:"oem148.inf"
INF Section:"Section048"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\nvddi.inf_amd64_6b0ab0a43cab35f6\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvddi.inf_amd64_6b0ab0a43cab35f6\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvddi.inf_amd64_6b0ab0a43cab35f6\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvddi.inf_amd64_6b0ab0a43cab35f6\nvldumdx.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"NVIDIA"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_10DE&DEV_2208&SUBSYS_389D1028&REV_A1\4&209E2803&0&0008"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"239 Hz"
Refresh Rate - Maximum:"239 Hz"
Refresh Rate - Minimum:"56 Hz"
Resolution:"5120 X 1440"
Scan Mode:"Noninterlaced"
Service Name:"nvlddmkm"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"NVIDIA GeForce RTX 3080 Ti"
- "Memory"
Physical Memory (Available):"84.18 GB"
Physical Memory (Installed):"96 GB"
Physical Memory (Total):"95.80 GB"
- "DIMM1"
Capacity:"32 GB"
Channel:"DIMM1"
Configured Clock Speed:"3600 MHz"
Configured Voltage:"1100 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"859B0000802C"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CT32G48C40U5.M16A1"
Serial Number:"E7007039"
Status:"Not Available"
Type:"Synchronous"
- "DIMM2"
Capacity:"16 GB"
Channel:"DIMM2"
Form Factor:"DIMM"
Interleave Position:"Second position"
Manufacturer:"80AD000080AD"
Part Number:"HMCG78MEBUA081N"
Serial Number:"13A00C3E"
Type:"Synchronous"
- "DIMM3"
Capacity:"32 GB"
Channel:"DIMM3"
Form Factor:"DIMM"
Serial Number:"E700703C"
Type:"Synchronous"
- "DIMM4"
Capacity:"16 GB"
Channel:"DIMM4"
Form Factor:"DIMM"
Serial Number:"13A00C32"
Type:"Synchronous"
- "Motherboard"
BIOS:"1.20.0, ALWARE - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"05/28/2024 08:00 PM"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"0C92D0"
Serial Number:".717L3L3.CNFCW001B600ZW."
Status:"OK"
Version:"A00"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 AM"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.1150"
Index:"0013"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"11/08/2024 03:45 PM"
MAC Address:"F4:26:79:05:D4:E8"
Manufacturer:"Microsoft"
Net Connection ID:"Bluetooth Network Connection"
NetCfgInstanceId:"{C90F2B7F-E691-4B19-B00B-C167C7B376C0}"
PNP Device ID:"BTH\MS_BTHPAN\6&21B4C5A2&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
- "Killer E3100G 2.5 Gigabit Ethernet Controller"
Caption:"Killer E3100G 2.5 Gigabit Ethernet Controller"
DHCP Enabled:"Yes"
Driver:"e3k25cx21x64.sys"
Driver Date:"07/29/2024 12:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e3k25cx21x64.inf_amd64_086d7953e92f24a1\e3k25cx21x64.sys"
Driver Provider:"Killer"
Driver Version:"1125.20.729.2024"
Index:"0002"
INF:"oem142.inf"
INF Section:"RTL8125BG.ndi.NT"
Installed:"Yes"
MAC Address:"74:86:E2:00:FA:9E"
Manufacturer:"Killer"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{E8F49512-7B44-4EFF-97CF-2E5CF6E389FA}"
PNP Device ID:"PCI\VEN_10EC&DEV_3000&SUBSYS_31021A56&REV_06\01000000684CE00000"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Killer E3100G 2.5 Gigabit Ethernet Controller"
Service Name:"e3k25cx21x64"
Status:"Enabled"
QoS Packet Scheduler:
- "Settings"
*EEE:Energy-Efficient Ethernet:"Disabled (0)"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Frame:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload v2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload v2 (IPv6):"Enabled (1)"
*PMARPOffload:ARP Offload:"Enabled (1)"
*PMNSOffload:NS Offload:"Enabled (1)"
*PriorityVLANTag:Priority & VLAN:"Priority & VLAN Enabled (3)"
*ReceiveBuffers:Receive Buffers:"1024 (1024)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*TransmitBuffers:Transmit Buffers:"512 (512)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on pattern match:"Enabled (1)"
AdvancedEEE:Advanced EEE:"Disabled (0)"
EEEMaxSupportSpeed:EEE Max Support Speed:"1.0 Gbps Full Duplex (1000)"
EnableGreenEthernet:Green Ethernet:"Enabled (1)"
GigaLite:Gigabit Lite:"Enabled (1)"
PowerSavingMode:Power Saving Mode:"Enabled (1)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Shutdown Wake-On-Lan:"Enabled (1)"
WolShutdownLinkSpeed:WOL & Shutdown Link Speed:"10 Mbps First (0)"
- "Killer(R) Wi-Fi 6E AX1675x 160MHz Wireless Network Adapter (210NGW)"
Access Point:
Authentication:"WPA2-Personal"
Caption:"Killer(R) Wi-Fi 6E AX1675x 160MHz Wireless Network Adapter (210NGW)"
Channel:"157"
Cipher:"CCMP"
Connection Mode:"Auto Connect"
Default IP Gateway:"192.168.1.1;fe80::8ade:7cff:feec:92eb"
DHCP Enabled:"Yes"
DHCP Lease Expires:"11/09/2024 03:46 AM"
DHCP Lease Obtained:"11/08/2024 03:46 PM"
DHCP Server:"192.168.1.1"
Driver:"Netwtw14.sys"
Driver Date:"09/26/2024 12:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\netwtw6e.inf_amd64_e02b45c1bfbf6f00\Netwtw14.sys"
Driver Provider:"Intel"
Driver Version:"23.90.0.2"
Index:"0000"
INF:"oem123.inf"
INF Section:"Install_RIV_SLR_TyP_1675x_AX_6G_2x2_WinT"
Installed:"Yes"
IP Address:"192.168.1.142;fe80::4a98:3b92:5c07:1287;2603:6011:9b00:ae6:282a:10bd:727d:fc53;2603:6011:9b00:ae6:c9:a7e5:1c7:88b6;2603:6011:9b00:ae6::11b0"
IP Subnet:"255.255.255.0;64;128;64;128"
MAC Address:"F4:26:79:05:D4:E4"
Manufacturer:"Intel Corporation"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{4F01FCDF-C43A-4D47-90EB-BED4E62B9D9D}"
Network Name:"SpectrumSetup-EA"
Network Type:"Infrastructure"
PNP Device ID:"PCI\VEN_8086&DEV_2725&SUBSYS_16741A56&REV_1A\4&418FA9F&0&00E7"
Product Type:"Killer(R) Wi-Fi 6E AX1675x 160MHz Wireless Network Adapter (210NGW)"
Profile:"SpectrumSetup-EA"
Radio Type:"802.11ax"
Receive Rate:"1201 Mbps"
Service Name:"Netwtw14"
Signal Strength:"92%"
State:"connected"
Status:"Enabled"
Transmit Rate:"1201 Mbps"
- "Settings"
*DeviceSleepOnDisconnect:Sleep on WoWLAN Disconnect:"Disabled (0)"
*PacketCoalescing:Packet Coalescing:"Enabled (1)"
*PMARPOffload:ARP offload for WoWLAN:"Enabled (1)"
*PMNSOffload:NS offload for WoWLAN:"Enabled (1)"
*PMWiFiRekeyOffload:GTK rekeying for WoWLAN:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
ChannelWidth24:Channel Width for 2.4GHz:"Auto (1)"
ChannelWidth52:Channel Width for 5GHz:"Auto (1)"
ChannelWidth6:Channel Width for 6GHz:"Auto (1)"
CtsToItself:Mixed Mode Protection:"RTS/CTS Enabled (0)"
FatChannelIntolerant:Fat Channel Intolerant:"Disabled (0)"
IbssTxPower:Transmit Power:"5. Highest (100)"
IEEE11nMode:802.11n/ac/ax Wireless Mode:"4. 802.11ax (3)"
Is6GhzBandSupported:Ultra High Band (6GHz):"Enabled (1)"
MIMOPowerSaveMode:MIMO Power Save Mode:"Auto SMPS (0)"
RoamAggressiveness:Roaming Aggressiveness:"3. Medium (2)"
RoamingPreferredBandType:Preferred Band:"1. No Preference (0)"
ThroughputBoosterEnabled:Throughput Booster:"Disabled (0)"
uAPSDSupport:U-APSD support:"Disabled (0)"
WirelessMode:802.11a/b/g Wireless Mode:"6. Dual Band 802.11a/b/g (34)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Internet Explorer,11.1882, Microsoft Edge,130.0"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"6.00 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.26100 Build 26100"
Virtual Memory (Available):"88.81 GB"
Virtual Memory (Total):"101.80 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5044384:"Update [10/29/2024]"
KB5045934:"Update [10/29/2024]"
KB5046683:"Update [10/29/2024]"
KB5046908:"Update [10/29/2024]"
- "Processor"
- "12th Gen Intel(R) Core(TM) i9-12900KF"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 151 Stepping 2"
- "Chipset Name":"12th Gen Intel(R) Core(TM) i9-12900KF"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=12th+Gen++Core+i9+12900KF"
CPU Speed:"3.19 GHz"
Current Voltage:"1.9 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 AM"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.26100.2161"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"16 x 384 KB"
Level 2 Cache:"16 x 14336 KB"
Level 3 Cache:"30 MB"
Load:"2%"
Manufacturer:"GenuineIntel"
Model:"151"
Name:"12th Gen Intel(R) Core(TM) i9-12900KF"
Number of Cores:"16"
Number of Cores Enabled:"16"
Number of Logical Processors:"24"
Processor ID:"BFEBFBFF00090672"
Revision:"Not Available"
Serial Number:"Not Available"
Service Name:"intelppm"
Status:"OK"
Stepping:"2"
- "Storage"
- "NVMe CT2000P5PSSD8"
Capablities:"Random Access, Supports Writing"
Caption:"NVMe CT2000P5PSSD8"
Cylinder - Total:"243201"
Description:"Disk drive"
Error Code:"Device is working properly"
Firmware Revision:"P7CR403"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Standard disk drives)"
Model:"NVMe CT2000P5PSSD8"
Partitions:"3"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_CT2000P5PSSD8\4&387BA32E&0&040000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"4"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Per Track:"63"
Sectors - Total:"3907024065"
Serial Number:"0000_0000_0000_0001_00A0_7522_3B4C_240D."
Size – Available:"1.80 TB"
SMART Attributes:"Self-Test: 0 minutes, OK, Short Self-Test: 0 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"62016255"
- "D:"
Availability:"Not Available"
Caption:"D:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"08A1F753"
Size – Available:"1846.26 GB"
Volume Dirty:"No"
- "SMART"
0x05 Reallocated Sector Count:0:"0"
0x09 Power-On Hours:292:"0"
0x0C Power Cycle Count:1464:"0"
0xAE Power-off Retract Count:399:"0"
0xBB Uncorrectable Error Count:0:"0"
0xBE Temperature - Current:32° C:"0"
0xBE Temperature - Highest:Not Available:"0"
0xBE Temperature - Lowest:Not Available:"17"
0xE8 Available Reserved Space:0:"50"
0xF1 Total LBAs Written:16142016:"0"
0xF2 Total LBAs Read:22715976:"0"
- "NVMe KXG70ZNV1T02 NVMe KIOXIA 1024GB"
Caption:"NVMe KXG70ZNV1T02 NVMe KIOXIA 1024GB"
Cylinder - Total:"124519"
Firmware Revision:"10804106"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Model:"NVMe KXG70ZNV1T02 NVMe KIOXIA 1024GB"
Partitions:"5"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_KXG70ZNV1T02_NVM\4&387BA32E&0&020000"
SCSI Bus:"2"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Total:"2000397735"
Serial Number:"0000_0000_0000_0000_8CE3_8E05_009B_7DEB."
Size – Available:"784.43 GB"
Status:"OK"
Tracks - Total:"31752345"
- "C:"
Caption:"C:"
File System:"NTFS"
Serial Number:"8669793F"
Size – Available:"784.29 GB"
Volume Dirty:"No"
- "SMART"
0x09 Power-On Hours:7562:"0"
0x0C Power Cycle Count:2414:"0"
0xAE Power-off Retract Count:578:"0"
0xBE Temperature - Current:42° C:"0"
0xF1 Total LBAs Written:69879944:"0"
0xF2 Total LBAs Read:94372682:"0"
- "SanDisk Ultra USB 3.0 USB Device"
Capablities:"Random Access, Supports Writing, Supports Removable Media"
Caption:"SanDisk Ultra USB 3.0 USB Device"
Cylinder - Total:"7477"
Firmware Revision:"1.00"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Interface Type:"USB"
Model:"SanDisk Ultra USB 3.0 USB Device"
Partitions:"1"
PNP Device ID:"USBSTOR\DISK&VEN_SANDISK&PROD_ULTRA_USB_3.0&REV_1.00\0501E634EB8DB101B56E9592EC336CEA47A2F06B47451E4111DF497A7B87BF2"
Sectors - Total:"120118005"
Serial Number:"0501e634eb8db101b56e"
Size – Available:"51.50 GB"
Status:"OK"
Tracks - Total:"1906635"
- "E:"
Caption:"E:"
Description:"Removable Disk"
File System:"exFAT"
Serial Number:"2ECD6B30"
Volume Dirty:"No"
...#SSU#...
NicholasMoore87
LeonWaksman
In this case better check for upgrades in DELL site.  I suggest that you should use the automatic tool in Dell site as a first option.
Leon
NicholasMoore87
can i ask u something else when i boot the system i get this
i only use the top one on volume 3 because the bottom one doesnt work idk i think it happened when I tried resetting once and my monitor kept not turning on so i had to restart the pc mutiple times and some how i got it going on different volume but one didnt finish setting up correctly so i did i tried reset it again and somehow i got windows installed but the other windows is still there that was not able to complete setup
but can i delete that in the system configuration? or will that mess stuff up
not the one highlighted  but the one on the bottom called windows 11 if i remove that will it also remove it up in the other window when i login so it just goes straight to 1 boot?
LeonWaksman
Hi @NicholasMoore87
Sorry for late answer. I was out of my desk.
Before removing the redundant Windows partition, I suggest  that you should have full backup of your drive. Than follow the instruction in the video clip.
Leon
NicholasMoore87
heres are the results
Scan Info:
Version:"3.0.0.2"
Date:"11/08/2024"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
System SKU:"0AAB"
- "Display"
Bits Per Pixel:"32"
INF:"oem148.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "DIMM1"
Capacity:"32 GB"
Channel:"DIMM1"
Form Factor:"DIMM"
Type:"Synchronous"
- "DIMM2"
Capacity:"16 GB"
Channel:"DIMM2"
Form Factor:"DIMM"
Type:"Synchronous"
- "DIMM3"
Capacity:"32 GB"
Channel:"DIMM3"
Form Factor:"DIMM"
Type:"Synchronous"
- "DIMM4"
Capacity:"16 GB"
Channel:"DIMM4"
Form Factor:"DIMM"
Type:"Synchronous"
- "Motherboard"
Product:"0C92D0"
Status:"OK"
Version:"A00"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0013"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
DHCP Enabled:"Yes"
Index:"0002"
INF:"oem142.inf"
Installed:"Yes"
Status:"Enabled"
- "Settings"
Access Point:
Channel:"157"
Cipher:"CCMP"
DHCP Enabled:"Yes"
Index:"0000"
INF:"oem123.inf"
Installed:"Yes"
State:"connected"
Status:"Enabled"
- "Settings"
- "Processor"
Architecture:"x64"
FPO:"Not Available"
INF:"cpu.inf"
Load:"2%"
Model:"151"
Status:"OK"
Stepping:"2"
- "Storage"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"3"
SCSI Bus:"4"
SCSI LUN:"0"
SCSI Port:"0"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"5"
SCSI Bus:"2"
SCSI LUN:"0"
SCSI Port:"0"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"1"
Status:"OK"
- "E:"
Caption:"E:"
File System:"exFAT"
Volume Dirty:"No"
...#SSU#...
RandyT_Intel
Hello NicholasMoore87,
Sorry for the delay in jumping in. I checked the thread and the error message you are getting while attempting to perform an update. The recommendations you've received from our enthusiast super users are helpful and direct to the point.
I just wanted to clarify and gather more information to better assist you with your concern. Based on the error message you posted; may I know if this came from the Intel Driver & Support Assistant (IDSA) or the Norton updater? I just want to make sure.
Could you also let me know which particular driver you are trying to update and why? Are you experiencing any specific issues with your system?
I reviewed the SSU report that you posted—thanks to our contributor who suggested it—and it appears you are using an OEM system, specifically a Dell unit Alienware Aurora R13. Please note that there is a difference between Intel® Software and Original Equipment Manufacturer (OEM)-supplied software. Your computer manufacturer might have customized drivers and software to enable or alter features or provide improved operation on your computer. Contact the manufacturer for the latest updates and technical support information. If you can no longer get driver support from your computer manufacturer, you can download generic Intel drivers.
Randy T.
RandyT_Intel
I wanted to follow up regarding the questions and information we shared with you recently. Have you had a chance to review them? Your feedback is invaluable in helping us determine the next best course of action.
Please let me know if you have any thoughts or if there's anything else you need from us.
Looking forward to your response!
Randy T.
RandyT_Intel
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
