23832 Discussions
Hide Intel® Driver & Support Assistant tray icon
Eugene
How do I disable Intel® Driver & Support Assistant from running on start up or disable a tray icon?
Each time I restart my laptop the icon is still there and there is no option to hide it from its settings.
Andronachi_Marian
Hi. You can try to open the 'Task manager -> Startup'. Check if the app is there and make Right click and press Disable.
Eugene
Hi, it is already disabled from Startup in the Task manager and CCleaner, but it launches anyway on Windows startup.
VARADHARAJAN
Valued Contributor II
Might be it was added in the list of task scheduler . or it was added in Registry key
My recommendation is not to disable or don't delete . just keep it keep
