23743 Discussions
Hot keys disable?
Hello Intel Community,
we will deploy next time a few new computers (500) over symantec Altiris. Windows 7 SP1 rollout.
We will integrate a new Intel grafik driver, today we use version 8.15.10.2182.
Many users give us repsonse, the hot key function => rotate display, is unsuitably 😞
We will disable this feature for all computers, over 900
It is possible to modify the driver ini, to disable hot key function or script after installation?
When yes, where can i finde the information about this modification.
thanks for help
DArce
Valued Contributor III
These kind of options are disabled when the driver is compiled by your Original Equipment Manufacturer itself who is the one that can add, remove or changes features on their systems.
In the other hand, if you are a system builder who develops their own systems and drivers, you should work on this directly using the Intel® Embedded Graphics Driver. For support on that you can use the information on this article:
http://www.intel.com/support/graphics/sb/CS-029828.htm?wapkw=iegd http://www.intel.com/support/graphics/sb/CS-029828.htm?wapkw=iegd
