23806 Discussions
How do I adjust power efficiency?
WJoen
Instructions for graphic command center say to adjust power efficiency, but I don’t see that option in the command center.
AndrewG_Intel
Hello WJoen
In order to assist you better, could you please provide the following information?
1- Where are you seeing the instructions for Intel® Graphics Command Center that is recommending to adjust power efficiency?
2- Why do you need to adjust this setting? Is this required for a specific configuration or are you experiencing any issues? Please provide more details.
3- Intel® Graphics Command Center version (you can find it under "Support >> System Diagnostic").
4- DxDiag* report following these steps:
  • In the keyboard, press WinLogo key + R.
  • In the Run box please type dxdiag and hit Enter.
  • Click on Save All Information.
  • Open the report.
  • Use the option "save all information" to save the .TXT file.
  • Attach the report .TXT file to this thread.
To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Andrew G.
AndrewG_Intel
Hello WJoen
If you need further assistance, please let us know. We will be glad to assist you.
Andrew G.
AndrewG_Intel
Hello WJoen
We have not heard back from you so we will proceed to close this inquiry. If you need further assistance please post a new question.
Andrew G.
