23801 Discussions
How do I install my LAN Driver?
I have a Toshiba Satellite A105-s4284 Laptop computer.I'm running Windows XP (SP3), which I recently had to reinstall.I found the LAN driver I needed from Toshiba's website:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1467727&rpn=PSAA8U&modelFilter=&selCategory=3&selFamily=1073768663 http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1467727&rpn=PSAA8U&modelFilter=&selCategory=3&selFamily=1073768663It's listed as:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1467727&rpn=PSAA8U&modelFilter=&selCategory=3&selFamily=1073768663# Intel PRO 10/100 Model Driver V8.0.43.0(v8.0.43.0; 12-18-2006; 425K)
When you download this file, you unzip it to a specified location and then you have to run the installer. The problem is that once I unzip to this location, there's an UN-installer, some system files, a few text files, and some DIN and .dll files but no executable Install files.Anyone know what's going on?
Try installing it manually.
Go in to Device Manager, select the NIC (yellow question mark) you right click on it and select update driver and then select the folder where the files where extracted.
PV.
