Asus ux32v.
So I have issues with the newest driver V9.17.10.2828, and when I install the V8.15.10.2761 everything works fine. But when I reboot my issues are back, so I guess the driver makes an update, I cant find how to disable this update.
just an idea: Have you the Intel HD driver center or something in your autostart folder?
You can check this by typing "msconfig" into the start-up menu.
So you could try to disable the center, that runs the update.
Hello Nicobkk, thanks a lot for posting your inquire at Intel communities.
If you are using Windows OS, this may be happening because you have Windows Update enable. So please try to disable this feature under control Panel.
Additional information could be found at the following link http://windows.microsoft.com/en-us/windows/turn-automatic-updating-on-off# turn-automatic-updating-on-off=windows-7 Turn automatic updating on or off - Windows Help
