22953 Discussions
How to adjust saturation on monitor when using HDMI?
LDavi11
My laptop uses Intel(R) HD Graphics 530 for it's displays and on the built in display the colors look fine, but on my external monitor the colors look really saturated. I have fiddled with all the buttons on the monitor and all the settings on my computer, downloaded all the latest drivers and the update utility but with no solution, I've tried other monitors and different cables but they all look the same. I tired using the Intel control panel but for some reason because I'm using HDMI, I can't adjust the saturation and hue on my monitor like I can with my built in display. Is there any way to fix this?
Hello The_Guy ,
Thank you for joining the Intel communities.
In order to better assist you I will appreciate if you could attach the Intel® SSU (System Support Utility) file.
This is a new Intel tool that will eventually incorporate gathering all the data needed in one click.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Download the utility
Run the exe and select 'Scan'
Save and include as an attachment in the Intel Community Forum
Also, I will appreciate if you can provide us with the monitor models that you have tested and the driver version you have installed.
Ivan
I'm just following on this thread to ask you if your issue was resolved or if you you could provide us the information requested above to better assist you.
Ivan
