23538 Discussions
How to apply HDCP in Protected Media Path (PMP).
JJin-
Hello, I'm try that apply HDCP in PMP (Protected Media Path).
i had set the HDCP, and given SRM data that required.
but, i had get a error that was "E_FAIL".
that error's mean that srm data was invalid? or other value was invalid?
please tell me about that error.
DArce
Valued Contributor III
You should check on this on the http://software.intel.com/en-us Intel® Developer Zone support communities as the appropriate channel for this type of concern.
JJin-
Thanks your answer. I had searched for the following keyword:"media foundation", "protected media path", "hdcp"
But, I can't find any solution for this problem.
I have some following question:
1st, I having use the INTEL inner graphic card (its 4400 series). This graphic card are supported "Protected Media Path" and "HDCP"?
2nd, I had given the SRM data. But, why returned error? SRM data was wrong?
Thanks your kindness.
