22946 Discussions
How to disable or override EDID to prevent window repositioning?
ROlin1
Integrated Intel HD Graphics 4600
First off, I would like to tell Intel that your tech support registration process absolutely sucks. Its a blog/forum, not a bank account. That password requirement is ridiculous....I won't ever remember it.
Now with that frustration out of the way, I am having the dreaded EDID asleep/off issue. I have two monitors connected via DisplayPort - 1 per port. When I am done or away from my computer I physically power off the monitors. When I turn them back on all my open windows/applications on monitor 2 have resized and been repositioned back over to monitor 1. All my research shows this a DP/HDMI issue that can be fixed by over riding the EDID setting that tells the computer when monitors are off (which in turn causes PnP havoc on screens). However, there is no setting (that I can find) within the Intel HD Graphics Control Panel to turn off EDID
I have two HP Compaq LA2306 LCD Monitors, and my graphics Driver version is : 10.18.14.4156. (3/3/2015). The are both in horizontal position with display settings set to 1920 x 1080.
How can I fix this? Its getting quite frustrating having to reposition my apps/windows every time I turn my monitors on.
My monitors are set to:
Power Saver: off
Further monitor and system info below:
Intel(R) HD Graphics 4600
Report Date: Thursday, June 25, 2015
Report Time [hh:mm:ss]: 10:20:02 PM
Driver Version: 10.18.14.4156
Operating System: Windows* 7 Professional (6.1.7601)
Default Language: English (United States)
Physical Memory: 12193 MB
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
Video BIOS: 2177.0
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i7-4765T CPU @ 2.00GHz
Processor Speed: 1995 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 11.0
Hardware-Supported Version: 11.0
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Digital Display *
Display Type: Digital
Serial Number: CNC1410LT8
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 20.08 inches
Vertical Size: 11.42 inches
Supported Modes
640 x 480 (60p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1440 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 22 F0 49 29 00 00 00 00
29 15 01 04 A5 33 1D 78 26 01 F5 A2 57 52 9F 27
0A 50 54 A1 08 00 81 C0 81 80 95 00 B3 00 D1 C0
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 FE 1F 11 00 00 1E 00 00 00 FD 00 32 4C 18
5E 11 00 0A 20 20 20 20 20 20 00 00 00 FC 00 48
50 20 4C 41 32 33 30 36 0A 20 20 20 00 00 00 FF
00 43 4E 43 31 34 31 30 4C 54 38 0A 20 20 00 31
* Digital Display2 *
Serial Number: CNC1410M4Z
Gamma: 2.2
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 720 (60p Hz)
1440 x 900 (60p Hz)
1680 x 1050 (60p Hz)</em...
pevan2
You mention Display Port.
The hotplug misfeature of DP means that when they are turned off (or you switch to a different input on same) they go away.
This causes me way more problems than HDMI ever did.
Solutions:
1 - never turn the monitors off.
2 - some sort of overpriced Display Port EDID emulator. (eg, matrix switch, extender etc)
3 - connect over some other medium that is not broken, HDMI, or DVI?
Almost certainly, 1 and 2 are not going to crank your tractor, but 3 might be workable.
Allan_J_Intel1
Some customers are requesting new features to be added on the graphics driver. This is still under investigation and there is not an estimate time of resolution, please take a look at the following thread:
Allan.
