22845 Discussions
How to force enable combined mode for different device id
Bartekf
Dear Intel,
I am working on setup where I plan to use 3 displays in Combined mode.
OS:  Windows 10 Enterprise
Version 22H2
OS build 19045.3208
My driver revision is:  Intel drivers - 27.20.100.9415
My graphic card is : Vendor 8086 Device ID: 9A49 Silicon rev. 01
My Monitor setup for combined mode is:
2 x Samsung TV connected via HDMI reported in Windows as SAM7129
with following EDID
"EDID"=hex:00,ff,ff,ff,ff,ff,ff,00,4c,2d,29,71,00,0e,00,01,01,1f,01,03,80,5f,\
  36,78,0a,a8,33,ab,50,45,a5,27,0d,48,48,bd,ef,80,71,4f,81,c0,81,00,81,80,95,\
  00,a9,c0,b3,00,d1,c0,04,74,00,30,f2,70,5a,80,b0,58,8a,00,50,1d,74,00,00,1e,\
  56,5e,00,a0,a0,a0,29,50,30,20,35,00,50,1d,74,00,00,1a,00,00,00,fd,00,18,4b,\
  0f,51,1e,00,0a,20,20,20,20,20,20,00,00,00,fc,00,53,41,4d,53,55,4e,47,0a,20,\
  20,20,20,20,01,45
  20,20,20,20,01,45
1 x Samsung TV connected via HDMI reported in Windows as SAM71B4
with following EDID
"EDID"=hex:00,ff,ff,ff,ff,ff,ff,00,4c,2d,b4,71,00,0e,00,01,01,1f,01,03,80,5f,\
  36,78,0b,a8,33,ab,50,45,a5,27,0d,48,48,bd,ef,80,71,4f,81,c0,81,00,81,80,95,\
20,20,20,20,01,b9
As you can see the monitor Device ID is slightly different 0x7128 vs 0x71b4 ( also windows reports them differently )
However I am able to enable Combined Display with these 3 displays.
However when I connect another display with  Manufacturer ID 0x2d4c and Device ID : 0x735a ( this is also Samsung ) I cannot enable combined mode with this display.
I have tried also fake_EDID but I guess I cannot change Device ID with this tweak ( only device capability can be changed )
I plan to connect different displays ( same manufacturer, same resolution , different size )
I can see that it is possible to enable combined mode with different Device ID ( example above )  - so this is not hardware limitation.
Please let me know how to force enable combined display with Intel graphic card  ( e.g. some flag/tweak  in registry or special config file )  ?
We are evaluation for our mass product solution few options: Intel is one of them.
Bartek
DeividA_Intel
Hello Bartekf,
Thank you for posting on the Intel® communities. I realize how complicated this issue is, and to help you further I would like to gather the following details.
1. What is the exact model of your GPU or integrated graphics? "Vendor 8086 Device ID: 9A49 Silicon rev. 01" does not show anything in our system.
2. You mentioned "I am able to enable Combined Display with these 3 displays.", does this mean that you are able to use the feature "combined mode"?
3. You also mentioned, "when connecting another display with Manufacturer ID 0x2d4c and Device ID: 0x735a cannot enable combined". does this mean that you are able to use the feature "combined mode" as long as all monitors/TV have the same device ID? If so, what is the device that does not have the same device ID? Is it a different one from the ones that you provided?
4. What is the brand and model name of your CPU?
Deivid A.
DeividA_Intel
Hello Bartekf,
I am following up to confirm if you had the time to collect the information requested, this will help me to have a better view of this issue.
Let me know if you need further assistance.
Deivid A.
Bartekf
Hello Deivid.
sorry I was busy with other research.
At the beginning I would like to emphasize what I am asking for.
I want to connect 3 different display models -> this means they will have different EDID -> different model ID
and enable combined mode with all 3 displays.
To answer you questions:
ad1
here is decipher of device ID from Intel.
https://dgpu-docs.intel.com/devices/hardware-table.html
(and info from SSU )
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Iris(R) Xe Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(R) Xe Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Xe+Graphics"
CoInstallers:"oem208.inf,iTGLD_w10_DS,Internal,Intel(R) Iris(R) Xe Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdn64.sys"
Driver Date:"07.24.2023 02:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_209893c165df0d65\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.4577"
INF:"oem208.inf"
INF Section:"iTGLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_209893c165df0d65\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_209893c165df0d65\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_209893c165df0d65\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_209893c165df0d65\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_9A49&SUBSYS_C856144D&REV_01\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"59 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(R) Xe Graphics Family"
ad2
I am able to enable combined mode for 3 displays  in following set-up:
case 1.  3 x Displays from the same manufacturer ( e.g. Samsung ) and exactly the same device ID  0x7128
case 2.  Display 1 device ID  0x7128 , Display 2 device id  0x7128,  Display 3 device ID  0x71b4
I am unable to enable combined mode for 3 displays in following set-up
case 3.  Display 1 device ID  0x7128 , Display 2 device id  0x7128,  Display 3 device ID  0x735a
The request is to be able to enable combined mode for set-up like in case 3 ( and similar where Device ID doesn't match )
ad3
As you can see on the answer 2 and also in Intel's guideline - Combined mode can be enabled for device from the same manufacturer and the same model = case 1
It looks like I am able to enable combined mode when Device ID is little bit different ( only 2LSB are different ) = case 2
I want to enable combined mode when device ID is completely different ( I will use same resolution on all 3 displays ) =case 3
ad4
from ssu
Processor:"11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz , GenuineIntel"
 thanks,
Bartek
Bartekf
Hello Deivid
(looks like my reply post disappeared so I will post once more )
First to emphasize subject of my question and real life usage.
I want to connect 3 different model displays and enable all of them in combined mode.
Answer to your questions
ad1.
here is device id decipher from Intel
here is info from ssu
Bits Per Pixel:"32"
INF:"oem208.inf"
Monochrome:"No"
Status:"OK"
ad2
Below configuration - combined mode works for all 3 displays
case 1: 3 x Displays identical model from the same manufacturer ( Device ID  0x7128 )
case 2:  Display 1 device ID 0x7128 , Display 2 device ID 0x7128 , Display 3 device ID 0x71b4
Below configuration - combined mode cannot be enabled for display 3
case 3:  Display 1 device ID 0x7128 , Display 2 device ID 0x7128 , Display 3 device ID 0x735a
ad 3
like in the answer above case 1 and Intel's guideline - combined mode can be enabled for all 3 displays
As I tested as was able to enable combined mode also for case 2 ( Device ID is different by 2LSB )
I wasn't to able to enable combined mode in case 3 - and this is my request / question, I want to be able to enable combined mode when device ID are completely different
ad 4
thanks
Bartek
Bartekf
Hello Deivid
(looks like my reply post disappeared or I cannot see it so I will post once again)
ad1.
Bits Per Pixel:"32"
INF:"oem208.inf"
Monochrome:"No"
Status:"OK"
ad2
ad 3
ad 4
thanks
Bartek
DeividA_Intel
Hello Bartekf,
Thanks for the information provided. In order to investigate this issue, I would like to gather the following:
1. Try clean installation of the latest Intel graphics drivers 31.0.101.4644:
2. What is the band and model name of the monitor ID 0x735a? This is to check compatibility.
3. Provide the Report for Intel® Graphics Drivers using the "case 3" setup:
4. Provide the complete report from the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
DeividA_Intel
Hello Bartekf,
I am following up to confirm if you are still experiencing issues with setting the display mode desired. Please let me know if you need further assistance or if you manage to fix the issue.
Deivid A.
DeividA_Intel
Hello Bartekf,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
