22963 Discussions
How to get third monitor detected? Lenovo X220
I have a Lenovo X220 with docking station, a second monitor connected via the VGA, I added another monitor using the USB port, and a DVI to VGA adaptor as recommended: but this monitor is not detected.
OS Windows 7 pro (updated).
Would be grateful for help on how to configure the system to be able to detect third monitor.
thanks
my current card configuration is:
Intel(R) HD Graphics 3000
Report Date: 4/28/2012
Report Time[hr:mm:ss]: 8:57:46
Driver Version: 8.15.10.2342
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 3983 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 30 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2491 MHz
Vendor ID: 8086
Device ID: 0126
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2089.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Active Notebook Displays: 1
* Monitor *
Monitor Name: SyncMaster P2770H/P2770FH Analog
Display Type: Analog
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 23.62 inches
Vertical: 13.39 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
800 by 600 (60 Hz)
800 by 600 (56 Hz)
1024 by 768 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 960 (60 Hz)
1280 by 800 (60 Hz)
1440 by 900 (60 Hz)
1600 by 1200 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D 11 06 34 55 31 5A
23 14 01 03 0E 3C 22 78 2A EE D1 A5 55 48 9B 26
12 50 54 23 08 00 81 00 81 40 81 80 95 00 A9 40
B3 00 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 5C 56 21 00 00 1E 00 00 00 FD 00 38 3C 1E
51 11 00 0A 20 20 20 20 20 20 00 00 00 FC 00 53
79 6E 63 4D 61 73 74 65 72 0A 20 20 00 00 00 FF
00 48 43 4C 5A 38 30 31 33 32 33 0A 20 20 00 A5
* Built-in Display *
Monitor Name: ThinkPad Display 1366x768
Display Type: Digital
Gamma Value: 2.2
Maximum Image Size:
Horizontal: 11.02 inches
Vertical: 06.30 inches
1366 by 768 (50 Hz)
1366 by 768 (60 Hz)
Standby Mode: Supported
Suspend Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE E0 40 00 00 00 00
01 14 01 03 80 1C 10 78 EA 20 E5 92 55 54 92 28
25 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 3E 1C 56 96 50 00 19 30 30 20
36 00 15 9C 10 00 00 18 3E 1C 56 2A 51 00 64 30
30 20 36 00 15 9C 10 00 00 18 00 00 00 0F 00 8C
09 32 8C 09 28 14 09 00 06 AF 56 30 00 00 00 FE
00 42 31 32 35 58 57 30 31 20 56 30 20 0A 00 0F
* Other names and brands are the property of their respective owners. *
Allan_J_Intel1
Hi there!
A third monitor with the HD Graphics 3000 is not possible because your graphics controller can support up to two monitors, this means the built in LCD and an additional display.
Video cable adapters are not supported such VGA to DVI cable.
If you are interested in additional information see below
http://www.intel.com/support/graphics/sb/CS-031040.htm http://www.intel.com/support/graphics/sb/CS-031040.htm
Allan.
Hi Allan,
thanks so much for your help and answer.
Surprising, because the Lenovo documentation mentionned it was possible (http://www.partnerinfo.lenovo.com/partners/fr/products/downloads/thinkpad-xseries/Top_Options_ThinkPad_X220.pdf http://www.partnerinfo.lenovo.com/partners/fr/products/downloads/thinkpad-xseries/Top_Options_ThinkPad_X220.pdf page 18 and page 20)
can I change the HD Graphics 3000 to something that would allow connecting more monitors, and what should I get? any input on this would help
again thanks.
Adelaide
CE2
Hi adelaideb,
Is your USB-DVI Monitor Adapter for your 3rd adapter plugged into the Docking Station's USB? Or into the laptop's USB slot?
