23528 Discussions
I have a problem with intel graphics hd 4000
JVázq1
Hello! I can't connect to another screen with the HDMI port since a year or so. I tried to install the latest version of the drivers and the problem keeps happening. I use the same cable and TV with another lenovo laptop and have zero problems, but in this one it doesn't even recognize that I plugged the HDMI connector. I have no problems in ubuntu, so I'm fairly sure the intel driver in windows 10 is the problem
Hello ssaron,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with an HDMI connection in a computer with Intel® HD Graphics 4000 and Windows® 10.
Please let me know if you have tried in another HDMI ports, and if you are using splitters, docks, or any kind of adapters and converters.
To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
  1. In the keyboard, press WinLogo key + R.
  2. In the Run box please type dxdiag and hit Enter.
  3. Click on Save All Information (save it in your desktop).
  4. Please attach to this thread the TXT file with the report.
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Xavier A.
JVázq1
I'm not using any converters or such, Xavier, and here I'm attaching the info of the file
System Information
Time of this report: 10/10/2017, 16:32:52
Machine name: DESKTOP-ET5T33Q
Machine Id: {DBFE721B-B922-489E-86EC-0580F3A969BC}
Operating System: Windows 10 Home 64-bit (10.0, Build 14393) (14393.rs1_release_inmarket.170906-1810)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: LENOVO
System Model: 20195
BIOS: InsydeH2O Version 03.72.246DCN97WW(V8.10)
Processor: Intel(R) Core(TM) i3-3227U CPU @ 1.90GHz (4 CPUs), ~1.9GHz
Memory: 4096MB RAM
Available OS Memory: 3964MB RAM
Page File: 3828MB used, 1415MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_397717AA&REV_09
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: CMN1476
Native Mode: 1366 x 768(p) (60.010Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll
Driver File Version: 10.18.0010.4653 (English)
Driver Version: 10.18.10.4653
DDI Version: 11.2
Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 06/04/2017 07:00:00 p. m., 11158160 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4226-11CF-3766-7D19B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x397717AA
Revision ID: 0x0009
Driver Strong Name: oem39.inf:5f63e5341859ec8c:iIVBM_w10:10.18.10.4653:pci\ven_8086&dev_0166
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
Hello ssaron,
Thank you for the information. In this case I would recommend to uninstall and delete the driver in your system, and then install the previous version of the driver for the Intel® HD Graphics 4000 controller. This way you can test again and see if the issue is fixed.
Please follow the steps below to uninstall the graphics driver:
  1. On the keyboard, press WinLogo key + R, then type in devmgmt.msc
  2. Expand the Display Adapters section.
  3. Find the Intel Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
  4. Right-click the Intel Graphics Driver and select Uninstall.
  5. Select the check box Delete the driver software for this device.
  6. Reboot the computer after uninstall process has finished.
Please follow these steps in order to update the graphics driver:
  1. Download the graphics driver ZIP file: https://downloadmirror.intel.com/25977/eng/win64_153343.4425.zip
  2. Unzip the file to a designated location or folder.
  3. Right-click Windows Start icon and open Device Manager.
  4. Click Yes when prompted for permission from User Account Control.
  5. Expand the Display adapters section.
  6. Right-click the Intel® graphics entry and select Update Driver Software.
  7. Click "Browse my computer for driver software".
  8. Click "Let me pick from a list of device drivers on my computer".
  9. Click "Have Disk".
  10. Click "Browse".
  11. Access the designated location or folder, and access a folder called "Graphics".
  12. Select the file called "igdlh64" or "igdlh".
  13. Click Open, then click OK, and finally click Next. Drivers are now being installed.
  14. Reboot your computer when prompted.
Xavier A.
JVázq1
Xavier thanks for your time man, but I'm afraid it's still not working with the procedure you recomended. Do you think it's worth trying with W10 or should I better downgrade to W8.1 where it worked fine? As I said, when I use a HDMI to VGA converter there's no problem with the port, and I can still use the hdmi on Ubuntu. I let you a nex Dx diag if you need it:
https://mega.nz/# !t0hgiKZD!hRtzJqwfN7wQWI35Vu2UoGCN0eD6BegF5dOemOJOaUg
Thanks again!
Hello ssaron,
I am sorry to see that the issue is still happening. I would recommend then to try with the driver provided by the computer manufacturer, but after searching in the Lenovo™ website, I only found drivers supported up to Windows® 8.1: https://pcsupport.lenovo.com/no/en/products/laptops-and-netbooks/ideapad-s-series-netbooks/ideapad-s400-touch-notebook/downloads
If this is the case, it is very likely that the computer manufacturer is not providing support for this computer in Windows® 10, and this could be the cause of this issue.
Any way, I can recommend you to downgrade to Windows® 8.1 and try either with the driver from Lenovo™ or with the driver from Intel®. You mentioned that it worked fine with that version of Windows®, so I suppose you will not have any issue if you downgrade the operating system.
Xavier A.
JVázq1
Hello Xavier! Fortunately before I gave format to the hdd I tried a last resort. I did the procedure you told me with the HDMI connected at all moments. When I installed the driver it didn't work after the first reeboot, but i disconnected the hdmi and turned off the lap and then I connected it again and started the laptop. I don't know why, but it's working normally now! Thanks for the help man, and I hope Intel fixes the problem soon so I can go back to the newest drivers
Hello ssaron,
Well, I am glad that you were able to find a solution to the issue.
If you need further assistance, please do not hesitate in posting a new thread.
Xavier A.
tbalc
hello my friend. i have a smilliar problem too. i've graphics hd 4000 too. i suppose this hardware is not supported with win10. try the following things but most probably these will produce other problem.
if u have not lastest driver software update it. else try those:
1- open start menu
2- write control panel and open device manager
3- expand display adapter and right-click on intel and click update driver software
4- scan computer for driver and click on selecting from list option.
5- select "show compatible drivers" and find last updating. (check the date at right side)
6- than select and click next. screen will be gone and fix maybe. sorry for my english
feedback please
JVázq1
Hello tahirbalci, I tried to use your method but I couldn't get it to work... If no one can help me then I'll have to go back to W7
