23258 Discussions
I have intel HD graphics 620, windows 10, I can;t do hardware graphics aceleration
hfarr
Different versions of FIFA requested hardware graphics aceleration. There is no any option to make the hardware graphics aceleration. My laptop is HP Notebook, windows 10, intel HD graphics 620. I would be highly grateful if you could help me to fix this issue.
Thank you & best regards.
Stefan3D
Sounds like you are using the "Microsoft basic display adapter".
If so, install a hardware accelerated driver e.g. this:
hfarr
I have downloaded the software. But upon installation, I have recieved a message saying that "The driver being installed is not validated for this computer."
Stefan3D
install via "have disk method" as descibed at http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS Surface).
hfarr
it worked.
Thank you very much.
Hello Haytham,
I understand that hardware acceleration is not working on FIFA game.
Let me apologize for any inconvenience this issue may be causing to you.
Please try updating the graphics driver as suggested by Stefan3D, and if issue persists please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred
hfarr
Please find enclosed the attachemnet as per your reuest.
