22940 Discussions
I'm stuck on the bios with my new gpu
Maxime320
I'm stuck on the bios after installing a gt 750 on my e210882 but when I use the cpu graphic it works
AlHill
Glad it works.
AlHill
What is an e210882 ?  Provide the motherboard model number.  Look on the board for a sticker.  It will begin with a "D".
Do you know that the GT 750 is good?
Did you make any bios changes to video settings?
Is the photo you took with the monitor plugged into the GT 750?
Is your BIOS at the latest/last revision?
Maxime320
It's a DH77EB
The gpu is good
I didn't made any change in the bios unless allowing the graphic card in first if it's plugged in
Yes, the photo is when it's plugged in the gt 750
I can't update my bios so I think I'm in the last version
AlHill
Remove the card, and check the bios version by using F2 to enter the bios at boot.
Again, how do you know the card is good?  Does it work in another machine?
Maxime320
The version says 2012
Yes it work in another computer
AlHill
I need the full bioss string.
Maxime320
EBH7710H.86A.0053.2012.0213.1543
AlHill
Ok, you have a DH77EB motherboard:
https://ark.intel.com/content/www/us/en/ark/products/59505/intel-desktop-board-dh77eb.html
You have bios 0053, but the latest/last is 0103.  You can download the .BIO file from here:
https://web.archive.org/web/20191119131212/https://downloadcenter.intel.com/download/24426/BIOS-Update-EBH7710H-86A-?product=59505
So, you need to update your bios first.
Maxime320
I try to update my bios but can't access the Bios update menu now and I still didn't touched anything
AlHill
The GT 750 is removed, correct?
You put the .bio file on a usb2 stick?
Insert the stick into one of the black ports on the  rear of the  board.
When you boot, start hitting F7.  You should see the bios update screen.
After the bios update (the next boot), F2, then F9, then F10.
Now,  after all of this, tell me your OS, and are you booting in legacy or UEFI mode?
Maxime320
When I hit F7 my computer freeze and I'm not able to enter the bios update menu
AlHill
How many sticks of memory do you have?  If more than one, remove all but one and try again.  If that does not work, try another stick.
Maxime320
I have only 1 memory stick but that doesn't change, it stays stuck
AlHill
Could bee bad mamory....
But, in the meantime, let's try bios recovery:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/BIOS-Recovery-Update-Instructions.pdf
There will be a yellow jumper on your board.  Note the pins.  The jumper should be covering pins 1 and 2.
Follow the instructions in the above doc.
Maxime320
Everything work now, I've managed to put the graphics card in and it work. Thanks a lot for your help
AlHill
You were able to update the bios?
Maxime320
Yes I was, everything is now up to date
AlHill
Glad it works.
