23682 Discussions
I need help
LIbas
Hello i want to know what kind of Intel HD Graphics do i have? because everytime i check it on everyi possible way it just shows Intel HD Graphics , i can't identify which version of Intel HD Graphics i have , please help me identify my graphics card
Stefan3D
You need to read out the "device ID"
Official tool:https://github.com/GameTechDev/gpudetect Intel GPU detect
Only as source code available. If you don't know how to build it, use any other GPU tool and study this list:
https://raw.githubusercontent.com/GameTechDev/gpudetect/master/IntelGfx.cfg https://raw.githubusercontent.com/GameTechDev/gpudetect/master/IntelGfx.cfg
The code name above your device ID gives you an idea which graphics driver to install now or in future.
https://software.intel.com/en-us/articles/intel-graphics-developers-guides Here is a list of code names and matching generation numbers seen in announcements of new drivers.
Other tools:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel System Support Utility , detailed view, display, PNP device ID
https://www.techpowerup.com/gpuz/ GPU-Z
http://www.ozone3d.net/redirect.php?id=401 GPUCapsViewer
DXDIAG.EXE report, line Device Key: Enum\PCI\VEN_8086&DEV_xxx
Hello CoolPotato__,
I understand you would like to know the exact model number of the Intel graphics controller that comes in your computer.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
What is the issue you are having in the computer that is making you find the exact model number of the graphics controller?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello CoolPotato__,
I was wondering if you still need assistance regarding the graphics controller that comes in your computer. In case you still need assistance just let me know.
Fred D.
