22979 Discussions
I switched from gt 710 to intel uhd 630 recently. The issue is the display icons,windows,taskbar is large (like you just formatted). Resolution is max (1600x900) and display driver is up to date. HELP!!!!
AAham6
Attached 3 Screenshots if that helps.
AlHill
I never did like that 1600x900 resolution.
Doc
AAham6
AlHill
What is the make and model number of the monitor?
Doc
AAham6
n_scott_pearson
Have you verified that Windows has not applied a scaling multiplier? Go into Settings and then System. In the Display settings, ensure that the Scaling and Layout parameters have the scaling set to 100%.
Hope this helps,
AAham6
That is set to 100%. My windows is also up-to-date. IDK what's going on.
AlHill
That model does have a max resolution of 1600x900:
https://www.dell.com/ae/business/p/dell-e2016h-monitor/pd
Doc
