23281 Discussions
I uninstalled the video drivers and i can't install
meerythm
So, i have uninstalled my video drivers (Intel drivers) and now i can't install it. I have search a lot but i didn't found anything...
AlHill
You have provided no information.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
ClariceStarling
Valued Contributor II
Won't help you now, but for future reference, you should always have your new drivers downloaded and ready to install before you remove anything ... because you can't count on any computer things working the way they are supposed to in theory!
