23766 Discussions
ICH10 Family SMBus controller latency Problem
Hi
I have a big problem with latency with drivers on my win7 64
The latency goes threw the roof on boot and stays there.
I have disabled everything and used startup diagonstics to load just the syatem drivers.
But the only thing that will carm the latency down some what is the SMBus controller if i disable this the latency really goes down but still way to much over head in the latency.
I do not know where to go from here to fix the problem I have the newest drivers on my system for the SMBus I have v1.0.0.2 which was made 08/06/2010.
I get latency with the driver every 3 or 4 seconds.
But if I enable the SMBus again the resources are not enabled because it say it had a problem.
Before I disable the SMBus in device manager.
After I disable the SMBus in device manager.
As you can see there is a major differance in the results of the driver latency but not a fix for the real problem and how to find what is causing the problem.
Does anyoe have any idea what to do next, I have not touched the Bios settings to see if they make a difference because ,I do not want to mess about with the bios and make thing worse,I have a EX58-UD5 v1 board been out 2 years now so should not be suffering from bad drivers or bios really.
Quick update
Had a look in the bios and disabled a few things :
HEPT
EIST
Onboard Sound
c3/c6/c7
c1
But still the same results only the SMBus will reduce the latency so I guess its the only thing thats making the latency or most of it.
Another update
Formated my pc today and exactly the same on boot from the very start.
