22862 Discussions
INTEL RELEASED STABLE GRAPHICS DRIVER DCH_WHQL_25.20.100.6519 FOR WINDOWS 10 64 BIT ON 17-01-2018
VARADHARAJAN
Valued Contributor II
On 17-01-2019 Intel inc released fourth windows 10 modern graphics drivers DCH WHQL v25.20.100.6519 only for 64bit.
Operating System Support
On 9th Generation Intel® Core processors, 8th Generation Intel® Core processors, 7th Generation Intel® Core processors, 6th Generation Intel® Core and Intel® Mobile Xeon processors and related Pentium/Celeron:
• Microsoft Windows* 10-64 - Fall Creators Update (1709)
• Microsoft Windows* 10-64 - April 2018 Update (1803)
• Microsoft Windows* 10-64 - October 2018 Update (1809)
Note with this release, Intel HD graphics control panel won't be available, you can download from Microsoft store.
Intel releases only Generic DCH drivers with WHQL.
I would you to recommend install the customized and certified driver for your laptop or desktop MB model,
I am sharing only Generic driver in this post
I am sharing the direct downloading links from intel website
for graphics driver
https://downloadmirror.intel.com/28514/a08/dch_win64_25.20.100.6519.exe
for release notes .pdf
https://downloadmirror.intel.com/28515/eng/ReleaseNotes_DCH_25.20.100.6519.pdf
for more information about this driver dch 25.20.100.6519
https://downloadcenter.intel.com/download/28514/Intel-Graphics-Windows-10-DCH-Drivers
CONTENTS OF THE PACKAGE:
• Intel® Graphics Driver
• Intel® Display Audio Driver (10.26.00.05)
• Intel® Media SDK Runtime
• Intel® OpenCL* Driver
• Vulkan* Runtime Installer (1.1.95 )
VARADHARAJAN
WARNING: Failure to read the below may result in system instability
These new drivers labelled as Windows DCH graphics drivers aren't backward compatible with our previous graphics drivers we are now llabellingLegacy. This means if later you want to revert to a Legacy driver you will need to uninstall the driver via Windows Apps and Features and reboot the system before installing a Legacy driver. Failure to do so may result in minor to major system instability.
DO NOT use the INF / Have-Disk method to install or uninstall this driver as it bypasses the Intel installer designed to install these new drivers, thereby possibly resulting in minor to major system instability. For this reason, we're not providing the ZIP file for the next several driver releases while users transition to this new Microsoft driver platform.
For more information about DCH drivers
https://www.intel.com/content/www/us/en/support/articles/000031275/graphics-drivers.html
Highlights of this driver 25.20.100.6519.
• New Intel Audio Driver (10.26.00.05)
• Windows* ML Optimization
• Better support for Windows* 10 Ambient light sensor framework
• Power and performance improvements
• Some new games are supported like DAYZ,GRIS,BLADED FURY, CATHERINE CLASSIC,ATOM RPG Intel® UHD Graphics 620 or better.
• Enhanced support for Windows* 10 Ambient light sensor framework requires nits (light luminance/brightness unit) level driver interface support
Performance Improvements on this driver 25.20.100.6519:
• Improved shader cache performance of DirectML metacommands for Microsoft WinML- based applications on 7th Generation Intel® Core processor and higher.
• Performance improvements and optimizations for F1 2018* (DX 12*) on 6th Generation Intel® Core processors or higher.
• Functional and performance improvements in Vulkan driver.
Fixed issues on this driver 25.20.100.6519 :
• Intermittent crashes or hangs may occur in Battlefield V* (DX12*).
• Minor graphics anomalies may be observed in Farming Simulator 2019*.
• Optimization checkbox for gaming tuning in the Graphics Control Panel does not refresh after restoring settings in some systems.
• Video profile settings in Intel® Graphics Control Panel may not apply after white balance or color balance.
• Power consumption may be higher after disconnecting HDMI 2.0 display.
• 4K resolution may be lost when switched between HD and 4K monitors during sleep mode.
• Brightness compensation may be applied when in SDR (Standard Resolution) mode.
• Performance may be slightly lower on certain graphics workloads in full screen after resuming from sleep.
Known issues on this driver 25.20.100.6519 :
• Intermittent crashes or hangs may occur in Cinema4D* application, and some games.
• Minor graphics anomalies may be observed in Battlefield V* (DX11*), and other games.
Be sure to check out gameplay.intel.com, where you’ll find recommended game settings for many more of your favorite PC games.
Install the Intel® Driver & Support Assistant, which automatically checks for drivers on a regular basis and can provide notifications when new drivers are available.
for more information about Intel DSA faq , visit below site
https://www.intel.com/content/www/us/en/support/topics/idsa-faq.html
VARADHARAJAN
The following graphics cards or controllers are supported::
9th Generation Intel® Core™ processors with Intel® UHD Graphics 630
8th Generation Intel® Core™ processors with Intel® Iris® Plus Graphics 655
8th Generation Intel® Core™ processors with Intel® UHD Graphics 610/620/630/P630
7th Generation Intel® Core™ processors with Intel® Iris® Plus Graphics 640/650
7th Generation Intel® Core™ processors with Intel® HD Graphics 610/615/620/630
Intel® Xeon® processor E3-1500M v5 family with Intel® HD Graphics P630
Pentium Processors with Intel® HD Graphics 610
6th Generation Intel® Core™ processors with Intel® Iris® Pro Graphics 580
6th Generation Intel® Core™ processors with Intel® Iris® Graphics 540/550
6th Generation Intel® Core™ processors with Intel® HD Graphics 520/530
Intel® Xeon® processor E3-1500M v5 family with Intel® HD Graphics P530
Intel® Xeon® processor E3-1500M v5 family with Intel® Iris Pro Graphics P580
Intel® Core™ M processors with Intel® HD Graphics 515
Pentium® and Celeron® Processors with Intel® HD Graphics 500/505/510
Pentium® and Celeron® Processors with Intel® UHD Graphics 600/605
VARADHARAJAN
The following hardware device ID's are only supported in this driver 25.20.100.6519,
if your device ID is missing , then this driver 25.20.100.6471 does not supported.
; SKY LAKE
%iSKLULTGT1%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_1906
%iSKLULTGT2%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_1916
%iSKLULXGT2%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_191E
%iSKLDTGT2%         = iSKLD_w10_DS, PCI\VEN_8086&DEV_1912
%iSKLULTGT2f%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_1921
%iSKLULTGT3e%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_1926
%iSKLULTGT3%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_1923
%iSKLULTGT328W%     = iSKLD_w10_DS, PCI\VEN_8086&DEV_1927
%iSKLDTGT1%         = iSKLD_w10_DS, PCI\VEN_8086&DEV_1902
%iSKLHaloGT1%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_190B
%iSKLHaloGT4%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_193B
%iSKLHaloGT3fe%     = iSKLD_w10_DS, PCI\VEN_8086&DEV_192B
%iSKLHaloGT2%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_191B
%iSKLSRVGT3e%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_192D
%iSKLSRVGT4%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_193A
%iSKLWSGT2%         = iSKLD_w10_DS, PCI\VEN_8086&DEV_191D
%iSKLWSGT4%         = iSKLD_w10_DS, PCI\VEN_8086&DEV_193D
; APOLLO LAKE
%iBXTGTP%           = iBXTD_w10_DS, PCI\VEN_8086&DEV_5A84
%iBXTGTP12%         = iBXTD_w10_DS, PCI\VEN_8086&DEV_5A85
; KABY LAKE
%iKBLULTGT1%        = iKBLD_w10_DS, PCI\VEN_8086&DEV_5906
%iKBLULTGT2%        = iKBLD_w10_DS, PCI\VEN_8086&DEV_5916
%iKBLULTGT2F%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_5921
%iKBLULTGT3E15%     = iKBLD_w10_DS, PCI\VEN_8086&DEV_5926
%iKBLULTGT3E28%     = iKBLD_w10_DS, PCI\VEN_8086&DEV_5927
%iKBLULXGT2%        = iKBLD_w10_DS, PCI\VEN_8086&DEV_591E
%iKBLDTGT1%         = iKBLD_w10_DS, PCI\VEN_8086&DEV_5902
%iKBLDTGT2%         = iKBLD_w10_DS, PCI\VEN_8086&DEV_5912
%iKBLHALOGT1%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_590B
%iKBLHALOGT2%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_591B
%iKBLWGT2%          = iKBLD_w10_DS, PCI\VEN_8086&DEV_591D
%iKBLULTGT2R%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_5917
; AMBER LAKE
%iAMLULXGT2R%       = iAMLD_w10_DS, PCI\VEN_8086&DEV_591C
%iAMLULXGT2R7W%     = iAMLD_w10_DS, PCI\VEN_8086&DEV_87C0
; COFFEE LAKE
%iCFLDTGT1%         = iCFL_w10_DS, PCI\VEN_8086&DEV_3E90
%iCFLDTGT2%         = iCFL_w10_DS, PCI\VEN_8086&DEV_3E92
%iCFLDTWSGT2%       = iCFL_w10_DS, PCI\VEN_8086&DEV_3E96
%iCFLHALOGT2%       = iCFL_w10_DS, PCI\VEN_8086&DEV_3E9B
%iCFLHALOWSGT2%     = iCFL_w10_DS, PCI\VEN_8086&DEV_3E94
%iCFLULTGT3W28%    = iCFL_w10_DS, PCI\VEN_8086&DEV_3EA5
%iCFLULTGT3W28EU42% = iCFL_w10_DS, PCI\VEN_8086&DEV_3EA8
%iCFLDTGT1W35%      = iCFL_w10_DS, PCI\VEN_8086&DEV_3E93
%iCFLDTGT2W35%      = iCFL_w10_DS, PCI\VEN_8086&DEV_3E91
%iCFLDTGT2S8S2F1F%  = iCFL_w10_DS, PCI\VEN_8086&DEV_3E98
; WHISKEY LAKE
%iWHLULTGT2U42U2F2%   = iWHL_w10_DS, PCI\VEN_8086&DEV_3EA0
%iWHLULTGT1U41FU2F1F% = iWHL_w10_DS, PCI\VEN_8086&DEV_3EA1
; GEMINI LAKE
%iGLKGT2E18%        = iGLKD_w10_DS, PCI\VEN_8086&DEV_3184
%iGLKGT2E12%        = iGLKD_w10_DS, PCI\VEN_8086&DEV_3185
sources are taken from intel.com , downloadcenter.intel.com
Thanks for reading my post, if any user found this useful means, then reply to me, share this to others and like pos
