23525 Discussions
Impossible to install lastest driver version 15.40.34.4624
EGuic
Hi !
I tried a few times to install Intel graphics driver version 15.40.34.4624 but I received this message: "Your system don't have the minimum configuration to install the software", even if my configuration is normally compatible with it.
Can you help me with that ? Do I need to unistall something before, to do some manipulations, or something ?
I'm using a Windows 8.1 64bit, with an Intel(R) Core(TM) i5-4200H CPU @ 2.80 GHz and an Intel(R) HD Graphics 4600.
When I run Intel Processor Identification Utility, that's the result, if you need it :
Version: 5.70.20170629
Time Stamp: 2017/07/12 02:36:31
Operating System: 6.2-9200-
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 2
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i5-4200H CPU @ 2.80GHz
Type: 0
Family: 6
Model: 3C
Stepping: 3
Revision: 1C
Maximum CPUID Level: D
L1 Instruction Cache: 2 x 32 KB
L1 Data Cache: 2 x 32 KB
L2 Cache: 2 x 256 KB
L3 Cache: 3 MB
Packaging: µPGA/BGA
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: Yes
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: Yes
System Graphics: Intel(R) HD Graphics 4600
Base TDP: 47 W
Expected Processor Frequency: 2.80 GHz
Reported Processor Frequency: 3.29 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
Stefan3D
Download WHQL certified version in ZIP format from
https://downloadcenter.intel.com/download/26682/Graphics-Intel-Graphics-Driver-for-Windows-15-40- Download Intel® Graphics Driver for Windows* [15.40]
Create a system restore point
https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point
Install the desired driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
EGuic
Okay, so I tried with your method and the driver you advised me, but it did not work ...
It said that this driver isn't adapt to this version of Windows ... 😕
Stefan3D
Sorry, i didn't see you are running an old OS.
Use this driver instead:
EGuic
