23699 Discussions
Incorrect colors after Display Driver Update.
MKell8
I'd like to first say, that your Product/Program selection does not include the product in question, so I picked one that's close, but it's the 965
I am attempting to install my drivers for my Windows XP Home version Laptop on a Dell Inspiron 1525 with display drivers for "Mobile Intel(R) 965 Express Chipset".
I am looking to run a specific program that requires up to date drivers on the machine, I tried both of the two latest drivers available on your site for the device listed above (versions 6.14.10.5218 then 6.14.10.5029), but when I install those versions, it will make ALL of the colors of the screen distorted and incorrect. I can provide screenshots if there were an attachment option.
The program that's being attempting to run is World of Warcraft. I've been able to run it on this machine before, but not after I had to clean it from some viruses. If I uninstall the devices/drivers from Device Manager, it will revert back to Display Driver version 6.14.10.4868, but World of Warcraft will not allow it to run.
If I install one of the two later versions that is provided on your website for Windows XP Home, then it distorts the color, but World of Warcraft will start.
I've looked for ways to adjust the color settings on the computer, but at the moment I've been unable to locate anything that was successful. If you could give me a resolution to this matter, it would be much appreciated. Below my closing will be the DxDiag that I had run before installing the later versions of the drivers, before the color distortion.
Thank you for your time and assistance in this matter,
Michael
System Information
Time of this report: 12/26/2014, 14:29:17
Machine name: LAPTOP-REY
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron 1525
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A16
Processor: Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz (2 CPUs)
Memory: 3062MB RAM
Page File: 870MB used, 4077MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: The file d3d9d.dll is a debug version, which will run slower than the retail version.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 965 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 965 Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A02&SUBSYS_022F1028&REV_0C
Display Memory: 384.0 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4864 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/24/2007 17:22:52, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 8/24/2007 17:22:56, 5776928 bytes
Device Identifier: {D7B78E66-6942-11CF-9860-2522ADC2CB35}
Vendor ID: 0x8086
Device ID: 0x2A02
SubSys ID: 0x022F1028
Revision ID: 0x000C
Revision ID: 0x000C
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SigmaTel Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_8384&DEV_7616&SUBSYS_10280242&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: sthda.sys
Driver Version: 5.10.5515.0000 (English)
WHQL Logo'd: Yes
Date and Size: 5/10/2007 09:24:34, 1222840 bytes
Other Files:
Driver Provider: SigmaTel
HW Accel Level: Full
Cap Flags: 0xB5B
Min/Max Sample Rate: 44100, 96000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SigmaTel Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware...
Kevin_M_Intel
Hello Shadorunce,
Please note our drivers are generic drivers for mobile systems. This is because we provide the hardware to Computer Manufacture and they will design their own systems with special features and limitation that can be lost when installing our driver.
As per WoW game requirements, the mobile 965 is quite low graphics but my best recommendation is to contact the Computer Manufacture and get the driver for your system.
Here is the contact information:
http://www.intel.com/support/oems.htm http://www.intel.com/support/oems.htm
Kevin M
Kevin_M_Intel
Hello Shadorunce,
Kevin M
