23526 Discussions
Inject latest Intel AHCI into WinPE fails
Hi
I have a problem when I try to inject Intel AHCI driver with version 10.1.0.1008 into a WinPE boot image via SCCM console.
Receive following error message:
Error: Boot image to update:
Microsoft Windows PE (x86)
Error: Actions to perform:
Add ConfigMgr binaries
Disable Windows PE command line support
Add drivers
Success: Drivers that will be included:
Intel(R) ESB2 SATA RAID Controller
Error: Failed to import the following drivers:
Intel(R) ESB2 SATA AHCI Controller - Failed to inject a ConfigMgr driver into the mounted WIM file
Error: The wizard detected the following problems when updating the boot image.
The ConfigMgr Provider reported an error.: ConfigMgr Error Object:
instance of SMS_ExtendedStatus
Description = "Failed to insert OSD binaries into the WIM file";
ErrorCode = 2152205056;
File = "c:\\qfe\\nts_sms_fre\\sms\\siteserver\\sdk_provider\\smsprov\\sspbootimagepackage.cpp";
Line = 4262;
ObjectInfo = "CSspBootImagePackage::PreRefreshPkgSrcHook";
Operation = "ExecMethod";
ParameterInfo = "SMS_BootImagePackage.PackageID=\"HBG0007B\"";
ProviderName = "WinMgmt";
StatusCode = 2147749889;
Anyone encountered this problem before, and might have a workaround?
Best regards
US
