23662 Discussions
Integer texture support in Intel HD 4600
MJone15
Débutant
6 821 Visites
I am having a problem allocating 64x64 OpenGL textures of the format ALPHA16I_EXT (internal) / ALPHA_INTEGER_EXT.
GPU caps lists the GL_EXT_texture_integer extension as being available. The driver is 10.18.10.3345 (10-31-2013).
The machine is a Dell with a hybrid NVidia/Intel configuration.
My question is more a driver question than a dev question: should the HD 4600 support this texture format? Is there limited support?
0 Compliments
ROBERT_U_Intel
Employé
5 125 Visites
Hi Michael
The latest version of the OpenGL specs recommend not to use the alpha formats when only using one component.
Here's the list of formats with the deprecated ones highlighted in red (they are no longer part of the core version of the spec)
So my recommendation would be to use R16I/RED_INTEGER instead.
Robert
Voir la solution dans l'envoi d'origine
0 Compliments
4 Réponses
ROBERT_U_Intel
Employé
5 125 Visites
Hi Michael
I will check with our OGL developers and get back to you.
Robert
0 Compliments
ROBERT_U_Intel
Employé
5 126 Visites
Hi Michael
Robert
0 Compliments
MJone15
Débutant
5 125 Visites
Thanks. Offhand, I think that should work for us.
I will give it a shot and flag as answered if it works out.
0 Compliments
MJone15
Débutant
5 125 Visites
That worked. Thanks. The following specifics do the trick:
Data format: GL_SHORT
Texture format: GL_RED_INTEGER[_EXT]
Internal format: GL_R16I
Also, I did the same thing with a 32 bit alpha luminance, and used an RGBA16UI texture instead.
0 Compliments
Répondre
