23736 Discussions
Intel 4600 Display Drivers wont install correctly
Hi All
I have a HP 280 G1 that uses Intel HD4600 drivers. Problem is when I install it it just get Video Controller (VGA compatible). The Utility also installs but you can't run it. This means it can only run in 3 resolotions. I have also tried drivers from the site.
Any ideas
Hello kamikaze_worm,
Could you please let me know the operating system and the driver version you are running? Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
Amy.
Hello /thread/107446 kamikaze_worm,
I just wanted to check if you were able to install the Intel® HD Graphics, if the issue persists please let me know.
Amy.
