23713 Discussions
Intel 530 graphics driver causing graphics corruption
TTayl1
When installed my Intel 530 graphics driver ends up creating graphics corruption that can only be fixed through a hard reboot. I do not have any problems with the Microsoft basic display driver but when I install the driver the graphical corruption starts again. The corruption usually happens in low to idle load situations.
Is there anyway to fix this.
Hello, DatDerpyHorse:
Could you please provide us with the following;
  • Intel® HD Graphics driver version installed. Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
  • BIOS version.
  • Computer model.
  • CPU model.
  • Operating system and the build version.
Amy.
TTayl1
Driver Version: 20.19.15.4331
BIOS Version: American Megatrends Inc. P1.40, 25/1/2016
Computer Model: Custom Built
CPU Model: Intel i5-6400
OS: Microsoft Windows 10 Home N Build 10586
Thank you for the information.
Please, try the following:
Amy.
TTayl1
I have done this and it still happens.
It looks like this if this helps
Is there any chance you can test a different monitor/TV and test a different cable?
TTayl1
Yes I have done that many times.
I used to have a AMD R7 370 in my computer and it used to freeze. So I RMA'ed the graphics card to see if that was the issue. I also did the same with the MOBO. They both were replaced and the freezing was still happening. So i began to just use the intergrated graphics and the freezing was just replaced with the graphics corruption. I have already reinstalled Windows 10 with no affect while also replacing the Power Supply. I need help to fix this werid problem I can't even use my computer to play a simple game like CS:GO with out the graphic corruption popping up when at idle.
Let's try replacing the unit, so please contact us at http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support in order to check the replacement options for your processor.
Amy.
TTayl1
I have done just done that and the problem still arises. The only thing i haven't replaced is RAM and the HDD.
Can you test the new unit with a different RAM stick? This odd, but you already replaced the unit and the issue is still there, so with this we can narrow down the issue.
Amy.
/thread/100596 DatDerpyHorse, were you able to test the RAM?
Let me know your findings.
Amy.
TTayl1
Hey,
Im a student and the past week has been rlly busy for me. I will try to get new ram but looking at my bank account that's not rlly able to be done. Here in New Zealand RAM is not cheap
I understand, if possible take the NUC to a computer shop, maybe they could help you to test the RAM.
Amy.
Hello, /thread/100596 DatDerpyHorse:
Were you able to test the NUC?
Amy.
TTayl1
Replaced ram thnx it works fine now
/thread/100596 DatDerpyHorse, that is really good to hear! Hope you enjoy your NUC.
If you need further assistance let us know
Amy.
