23821 Discussions
Intel 945GM OpenGL 2.0
I can not get OpenGL 2.0 programs to run...
I am using a HP Mini 110-1100 Netbook with Windows7 Starter
Video Card Vendor: Intel
Renderer: Intel 945GM
OpenGL Version: 1.4.0 - Build 8.14.10.1930
GLU Version: 1.2.2.0 Microsoft Corporation.
I have TRIED to run Intel® Graphics Media Accelerator Driver for Windows* 7(exe) win7_1512754 driver version 15.12.75.4.1930 (8.15.10.1930) and still does not work.
Current pixel format: 6
Pixel Formats supported by this video card
# Type Flags Buf Type Color(R-G-B-A) Z-Depth Stencil Accum(R-G-B-A)
1 ICD 00008024 SGL RGBA 32 (8-8-8-8) 0 0 0(0-0-0-0)
2 ICD 00008025 DBL RGBA 32 (8-8-8-8) 0 0 64(16-16-16-16)
3 ICD 00008024 SGL RGBA 32 (8-8-8-8) 16 0 0(0-0-0-0)
4 ICD 00008025 DBL RGBA 32 (8-8-8-8) 16 0 64(16-16-16-16)
5 ICD 00008024 SGL RGBA 32 (8-8-8-8) 24 8 0(0-0-0-0)
6 ICD 00008025 DBL RGBA 32 (8-8-8-8) 24 8 64(16-16-16-16)
7 GEN 0000807C SGL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
8 GEN 0000807C SGL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
9 GEN 00008465 DBL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
10 GEN 00008465 DBL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
11 GEN 0000807C SGL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
12 GEN 0000807C SGL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
13 GEN 00008465 DBL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
14 GEN 00008465 DBL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
15 GEN 0000807C SGL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
16 GEN 0000807C SGL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
17 GEN 00008465 DBL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
18 GEN 00008465 DBL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
19 GEN 00000078 SGL RGBA 24 (8-8-8-0) 32 8 64(16-16-16-0)
20 GEN 00000078 SGL RGBA 24 (8-8-8-0) 16 8 64(16-16-16-0)
21 GEN 00000078 SGL RGBA 24 (8-8-8-8) 32 8 64(16-16-16-16)
22 GEN 00000078 SGL RGBA 24 (8-8-8-8) 16 8 64(16-16-16-16)
23 GEN 00000078 SGL CI 24 (8-8-8-0) 32 8 0(0-0-0-0)
24 GEN 00000078 SGL CI 24 (8-8-8-0) 16 8 0(0-0-0-0)
25 GEN 00000078 SGL RGBA 16 (5-5-5-0) 32 8 32(11-11-10-0)
26 GEN 00000078 SGL RGBA 16 (5-5-5-0) 16 8 32(11-11-10-0)
27 GEN 00000078 SGL RGBA 16 (5-5-5-8) 32 8 32(8-8-8-8)
28 GEN 00000078 SGL RGBA 16 (5-5-5-8) 16 8 32(8-8-8-8)
29 GEN 00000078 SGL CI 16 (5-5-5-0) 32 8 0(0-0-0-0)
30 GEN 00000078 SGL CI 16 (5-5-5-0) 16 8 0(0-0-0-0)
31 GEN 00000078 SGL RGBA 8 (3-3-2-0) 32 8 32(11-11-10-0)
32 GEN 00000078 SGL RGBA 8 (3-3-2-0) 16 8 32(11-11-10-0)
33 GEN 00000078 SGL RGBA 8 (3-3-2-8) 32 8 32(8-8-8-8)
34 GEN 00000078 SGL RGBA 8 (3-3-2-8) 16 8 32(8-8-8-8)
35 GEN 00000078 SGL CI 8 (3-3-2-0) 32 8 0(0-0-0-0)
36 GEN 00000078 SGL CI 8 (3-3-2-0) 16 8 0(0-0-0-0)
37 GEN 00000078 SGL RGBA 4 (1-1-1-0) 32 8 16(5-6-5-0)
38 GEN 00000078 SGL RGBA 4 (1-1-1-0) 16 8 16(5-6-5-0)
39 GEN 00000078 SGL RGBA 4 (1-1-1-8) 32 8 16(4-4-4-4)
40 GEN 00000078 SGL RGBA 4 (1-1-1-8) 16 8 16(4-4-4-4)
41 GEN 00000078 SGL CI 4 (1-1-1-0) 32 8 0(0-0-0-0)
42 GEN 00000078 SGL CI 4 (1-1-1-0) 16 8 0(0-0-0-0)
OpenGL extensions found for the current pixel format
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_blend_color
GL_EXT_abgr
GL_EXT_texture3D
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_cull_vertex
GL_SGIS_texture_edge_clamp
GL_SGIS_generate_mipmap
GL_EXT_draw_range_elements
GL_SGIS_texture_lod
GL_EXT_rescale_normal
GL_EXT_packed_pixels
GL_EXT_separate_specular_color
GL_ARB_multitexture
GL_EXT_texture_env_combine
GL_EXT_bgra
GL_EXT_blend_func_separate
GL_EXT_secondary_color
GL_EXT_fog_coord
GL_EXT_texture_env_add
GL_ARB_texture_cube_map
GL_ARB_transpose_matrix
GL_ARB_texture_env_add
GL_IBM_texture_mirrored_repeat
GL_EXT_multi_draw_arrays
GL_NV_blend_square
GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1
GL_EXT_texture_filter_anisotropic
GL_ARB_texture_border_clamp
GL_ARB_point_parameters
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar
GL_EXT_texture_compression_s3tc
GL_ARB_shadow
GL_ARB_window_pos
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_ARB_vertex_program
GL_ARB_fragment_program
GL_EXT_stencil_two_side
GL_ARB_vertex_buffer_object
GL_EXT_texture_lod_bias
GL_NV_texgen_reflection
GL_ARB_depth_texture
GL_WIN_swap_hint
DArce
Valued Contributor III
I suggest you to check the information on the following site:
http://www.intel.com/support/graphics/intel945gm/sb/CS-021517.htm http://www.intel.com/support/graphics/intel945gm/sb/CS-021517.htm
The Intel(R) Mobile Intel(R) 945GM Express Chipset supports up to OpengGL1.4 which may cause conflicts when you try to run an application that requires something higher.
