I would like to ask how to properly set up a functioning Audio Return Channel (ARC) on the Intel ARC A770 16GB graphics card. I have a primary Samsung C27HG7x monitor connected via DisplayPort, and I would like to use the HDMI port to connect the audio to my Sony HT-S20R sound system.
Could you please advise on the correct procedure or settings required for this configuration?
Thank you in advance for your assistance.
Hi @Druidinqo ,
- Is this your first time setting up this combination of devices?
- Have these components worked together without issues before?
- Are the latest drivers installed for the Intel ARC A770 graphics card?
- Have you configured the audio settings on your PC to route sound through the HDMI port?
- Have you checked the audio settings on your monitor and sound system to ensure ARC is enabled?
- Have you tried connecting the sound system directly to the monitor to test ARC?
- Please provide the SSU log report and share it here so I can review your system's configuration as well as the make and model of the cables used in set up.
ARC is typically used to send audio from a TV to a sound system. In your setup, ensure that the monitor and sound system both support ARC. If not, ARC may not be feasible.
Warm regards,
Randy T.
Hi @Druidinqo,
Warm regards,
Randy T.
Hi @Druidinqo,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Warm regards,
Randy T.
