23068 Discussions
Intel Arc A380 Driver won't install
BK-LLC
Hi;
I just bought and installed ASRock Intel Arc A380 Challenger ITX 6GB OC. However,  driver installation is proving to be a difficult task than it should be.
I have followed every installation guide I could find. Uninstalled and reinstalled repeatedly, still can't get this thing working beyond basic VGA mode.
I'm using 100% Intel provided drivers downloaded using Intel Driver & Support Assistant utility that automatically scan and install drivers as needed.
Intel SSU output log is attached.
Here are other error messages:
Intel® Arc™ & Iris® Xe Graphics - Windows*: Installation failed
Windows® 10 and Windows 11* Wi-Fi Drivers for Intel® Wireless Adapters: Installation successful
Intel® Wireless Bluetooth® for Windows® 10 and Windows 11*: Installation successful
My System Info:
OS: Windows 11 Pro -build 22H2 (10.0.22621)
Mobo: MAG Z590 TOMAHAWK WIFI (MS-7D08)
CPU: Intel Core i7-10700K CPU 3.80GHz
Andres_Intel
Hello BK-LLC,
Thank you for posting on the Intel®️ communities. I see that you are having driver installation issues with your Intel® Arc™ A380 Graphics, I understand how frustrating this can be, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
  • I see you mentioned that you received the following error messages:
    • Intel® Arc™ & Iris® Xe Graphics - Windows*: Installation failed
    • Windows® 10 and Windows 11* Wi-Fi Drivers for Intel® Wireless Adapters: Installation successful
    • Intel® Wireless Bluetooth® for Windows® 10 and Windows 11*: Installation successful.
Where did you receive those error messages? Are you able to take screenshots of it? This is to have a better idea of the issue.
Andres P.
Andres_Intel
Hello BK-LLC,
Were you able to check the previous post? To know where you receive those error messages.
Andres P.
Andres_Intel
Hello BK-LLC,
We have not response from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
