22946 Discussions
[Intel Arc A770 is not able boot] But internal graphic can able to boot os
Sudhir2024
Hello sir,
I have very old generation intel i7 3770k cpu
Motherboard is for Zerbonic h61 which i can able to get right now for my cpu .
16 gb ram
Arc a770 Gpu
Now the issue is
1. My system Boot perfectly with out gpu . means it able to boot and run fine
2. After install gpu after using DDU my system was not able to boot from gpu insted it boot from internal HD 4000 gpu. even i set my bios to look for pci e gpu as first boot device.
Broken solution
if i have to make gpu arc a770 work for me
there are 2 option for me  i need to disable internal gpu in bios. or else I need to disable internal gpu in device manager.
and magic happen my system boot form arc a770 gpu and able to install driver and able to work fine. and i tested it by restarting my system and it works
But issue comes when i shut down my system and then try to boot my system .
It Wont Boot or POST
so in need to remove my gpu and need to reset the bios, so it can able to boot from internal gpu
So plz provide me some solution . I have send you some bios image so you can able to guide me with the settings
Senkuchan
Valued Contributor II
According to the information you shared, your setup does not meet the compatibility criteria for arc graphics card, which requires 10th to 14 generation processors, while yours is 3rd generation. Hence, it is essential to verify the system requirements before purchasing an intel arc graphics card, as it also demands a motherboard that supports rebar. You can find more details by visiting this link:
https://www.intel.com/content/www/us/en/support/articles/000091128/graphics.html
If you still want to try some troubleshooting steps, you can refer to these articles:
https://www.intel.com/content/www/us/en/support/articles/000092760/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000094366/graphics.html
Senkuchan
