23527 Discussions
Intel Arc Driver Causing System Instability on HP OmniBook X Flip 16‑as0xxx
RaevanWolf
I am experiencing severe instability with the Intel Arc Graphics driver on my HP OmniBook X Flip 16‑as0xxx. After installing the latest Intel Arc driver (version 32.x), my system began freezing, black‑screening, and then force‑rebooting. After the most recent crash, Windows reverted to the Microsoft Basic Display Adapter, and the Intel driver failed to load on reboot.
System Details:
• Laptop: HP OmniBook X Flip 16‑as0xxx
• CPU: Intel® Core Ultra 7 256V
• GPU: Intel® Arc integrated graphics
• Driver version that caused instability: 32.x.x.xxxx
• Operating System: Windows 11
Symptoms:
• Random system freezes
• Black screen followed by forced reboot
• Event Viewer shows GPU driver crashes
• After reboot, Windows loads Microsoft Basic Display Adapter instead of the Intel driver
• Device Manager shows no option to roll back to a previous Intel driver
• Only the unstable Arc driver appears in the “Let me pick from a list” menu
Additional Context:
HP does not currently provide a stable Intel graphics driver for this model on their support website. Windows Update, HP Support Assistant, and Intel DSA all install the same unstable 32.x driver. There is no older 31.x HP‑validated driver available to revert to.
Request:
Please investigate this instability and provide a stable driver version for this GPU. If possible, I would appreciate access to a validated driver that does not cause system crashes or force Windows to fall back to the Basic Display Adapter.
Thank you
KentRusselP_Intel
Hi RaevanWolf,
Thank you for posting in the Intel Community Forum. I appreciate you reaching out, and I’m here to help you with this issue. To better understand what’s happening and provide the most accurate support, could you please share the details below:
  1. What is the exact version number of the 32.x driver causing the issue? Is it 32.0.101.6913 Rev. A? Please confirm.
  2. Did you perform a clean driver installation using DDU (Display Driver Uninstaller) before installing the 32.x driver?
  3. Was there an earlier Intel graphics driver version that worked without issues?
  4. Are you using any overclocking tools or have you changed power‑related settings?
  5. Do the crashes happen during specific activities (such as gaming, video playback, or while idle), or do they occur randomly?
  6. How long after starting the system do the crashes usually occur?
  7. Does the system stay stable for long periods when using the Microsoft Basic Display Adapter?
  8. Have you run Windows Memory Diagnostic or any other hardware stress tests?
  9. Have you tried installing the driver while in Safe Mode?
  10. Did you attempt to manually extract and install only the display driver, without the Intel software package?
Additional Information Requested
To help us review your system setup and investigate further, please provide the Intel® System Support Utility (SSU) logs, which include important hardware and software details. Steps to collect the SSU logs:
  1. Download and run the Intel® System Support Utility.
  2. The tool will generate a text file with your system information.
  3. Refer to this guide for full instructions: Help Guide for the Intel® System Support Utility
  4. Attach the generated file to your reply.
Event Viewer Logs
Please also share the Event Viewer log. You can collect it by following these steps:
1. Start Event Viewer by going to Start > search box (or press Windows key + R to open the Run dialog box) and type eventvwr.
Within Event Viewer, expand Windows Logs.
3. Click the type of logs you need to export.
4. Click Action Save All Events As...
5. Ensure that the Save as type is set to .evtx and save the log file to a destination of your choosing.
6. If you are prompted to display information, select the Display information... radio button and choose English and click OK.
7. This creates an .evtx file and a folder that is called LocaleMetaData in the directory that is specified in step 5. Add this file and directory to a compressed compressed file.
If you have any questions or need further assistance, please feel free to us know.
Kent Russel P.
RaevanWolf
Hi Kent,
Thanks for the quick response. Here are the details you requested:
• Driver version:
Yes, the unstable driver is 32.0.101.6913.
• Clean install with DDU:
No, I did not use DDU. The system became unstable immediately after the 32.x driver was installed through Windows Update, so I reverted to the Microsoft Basic Display Adapter to keep the system usable.
• Previous stable driver:
I never had access to the 31.x Production Branch. My system only ever received the 32.x driver through Windows Update and Intel DSA, and the issue began immediately after that driver was installed.
• Overclocking / power tools:
No, I am not using any overclocking tools or power‑related utilities. The system is running stock settings.
• Crash behavior:
The very first crash occurred while running EverQuest, but the instability continued afterward even during normal desktop use. Crashes occur randomly — sometimes during light tasks, sometimes during video playback, and sometimes shortly after login when the 32.x driver is installed.
• Time to crash:
Anywhere from 30 seconds to a few minutes after boot with the 32.x driver.
• Stability on Microsoft Basic Display Adapter:
The system becomes stable once it has fully booted into the Microsoft Basic Display Adapter. However, I still experience one crash on cold boot, before the system switches to the Basic driver. After that initial crash, the system runs normally.
• Memory / hardware tests:
I have not run Windows Memory Diagnostic yet. The issue appears tied specifically to the Intel 32.x graphics driver, as the system becomes stable once it switches to the Microsoft Basic Display Adapter.
• Safe Mode install:
No, I did not attempt installing the driver in Safe Mode because the system was unstable with the 32.x driver installed.
• Manual driver extraction:
No, I did not manually extract or install the INF-only driver. The instability occurs as soon as the 32.x driver is present on the system.
I’ve attached the requested SSU-Report.txt and EventViewerLogs.zip.
Please let me know if you need anything else.
RaevanWolf
KentRusselP_Intel
Hi RaevanWolf,
Thank you for your prompt response! . Please proceed to perform clean installation of graphics driver, 32.0.101.6913 Rev. A. Please perform the following:
Uninstall the current/previous graphics driver version using Display Drive Uninstaller (DDU) by following the instructions below:
  1. Download the latest version of the software.
    • If you download the Installer, run it, it will create a shortcut on the desktop.
    • If you download the Portable/ self-extracting version, look for the executable and extract it. Remember the path.
  1. Reboot into Windows* safe mode. (Refer to Start your PC in safe mode in Windows.)
  2. Look for the shortcut on the desktop (step 1.1) or the extract path chosen (step 1.2.1) and run the DDU executable.
  3. Click Close in the Options window.
  4. Select device type to GPU and select device to the one you want to remove. If you are doing a clean-up, you can choose all GPUs.
  5. Click Clean and restart or Clean and Shutdown depending on your needs.
  6. Wait for the software to finish the process. It will automatically reboot Windows to the typical mode or shutdown the system.
Here is the link for your reference: How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
After completely removing the previous/current driver, proceed to clean install OEM Graphics driver by downloading and installing 32.0.101.6913 Rev.A
Kent Russel P.
KentRusselP_Intel
Hi RaevanWolf,
I just wanted to follow up and check whether you’ve had an opportunity to review the information I shared previously. Your feedback is important, as it helps determine the best next steps moving forward. When you have a moment, I’d appreciate it if you could let me know your thoughts or provide any updates on your end.
If you have any questions, need additional clarification, or require further assistance, please don’t hesitate to reach out. I’m more than happy to help.
Kent Russel P.
KentRusselP_Intel
Hi RaevanWolf,
As I haven’t received a response, I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
