23746 Discussions
Intel® Arc™ Graphics - Windows* Installation failed with error code 1000
Samrat
The Intel Graphics Drivers fails to update using the Intel Driver and Support Assistant utility.
Any help is highly appreciated.
Below is the system details
JeanetteC_Intel
Hello Samrat,
I understand you're encountering Windows Installation error code 1000 when attempting to update your driver through Intel Driver & Support Assistant (Intel DSA). To better diagnose this issue and provide an effective solution, please help me with the following information:
  1. Can you confirm this is your actual device: ASUS Zenbook DUO (2024) UX8406 - Tech Specs|Laptops For Home|ASUS Global?
  2. Are you experiencing any display or graphics problems that prompted this driver update, or did Intel DSA notify you to update?
  3. Please verify that there are no pending Windows Updates.
  4. Could you share your SSU log file? This will help me review your system configuration and recommend the most suitable driver.
JeanetteC.
JeanetteC_Intel
Hello Samrat,
Have you had a chance to look over the previous post?
If you have any questions, please don't hesitate to reach out.
JeanetteC.
JeanetteC_Intel
Hello Samrat,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
