23792 Discussions
Intel® Arc™ & Iris® Xe Graphics - Windows*
FunkyPants
Hi everyone, i am new here
When i try to update the drive mention above it always fails to do so
I have a Galaxy Book 3
i also get this  below it :
Installing this graphics driver from Intel will remove customizations from your computer manufacturer (OEM)
If a newer graphics driver is available from Samsung , we recommend that you install that driver instead.
A customized computer manufacturer driver is installed on your computer. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues.
So, should i do it or leave it be!!!
Thank you !!
Mike_Intel
Hello FunkyPants,
That is why we recommend that the driver that you use is the latest from the manufacturer of your laptop.
The reason behind it is the manufacturer may have altered or modified the Graphics controller so installing Intel generic drivers
may not enable those enhancements.
As for the pop up, it is up to you if you want to proceed, however the recommended driver should come from the manufacturer of the laptop.
Michael L.
