23648 Discussions
Intel® Arc™ & Iris® Xe Graphics - Windows*
jmakry
Good morning
I have a Dell G15 laptop, it came with Windows 11 Home when I bought it
I upgraded it to Windows 11 Pro
I had to install the Intel® Graphics Driver 32.0.101.6913 version.
I installed it successfully.
After a while, in the Windows Update window, it came to download an old version 31.0.101.5382, which cannot be downloaded and installed automatically.
I downloaded it and installed it manually.
As you can see, it was installed and in the Intel Graphics Software window it shows the version 31.0.101.5382
This happens with every update that comes.
can you explain to me why this is happening???
can i overcome this problem???
can you help me ???
Mike_Intel
Hello jmakry,
For me to further investigate this issue, please help provide the following details:
  1. Aside from the driver version, are you having other issues with the graphics?
  2. How about in the device manager, what is the driver version visible there?
  3. Please help generate the SSU logs of your system, kindly refer to the link below on how to generate the logs:
Michael L.
jmakry
Καλημέρα
  1. Εκτός από την έκδοση του προγράμματος οδήγησης, αντιμετωπίζετε άλλα προβλήματα με τα γραφικά; = ΟΧΙ
  2. Τι γίνεται με το διαχειριστή συσκευών, ποια είναι η έκδοση του προγράμματος οδήγησης ορατή εκεί; =31.0.101.5382
jmakry
Καλημέρα
θα ήθελα να σας ευχαριστήσω για τις άμεσες απαντήσεις σας.
Το πρόβλημά μου έχει επιλυθεί και σας ευχαριστώ για την πολύτιμη βοήθειά σας.
Όχι, δεν θα χρειαστώ περαιτέρω βοήθεια.
Mike_Intel
Hello jmakry,
Thank you for the update.
Can you try following the steps in the link below:
Windows* Update Rolling Back Graphics Driver to a Previous Version
Michael L.
Mike_Intel
Hello jmakry,
Michael L.
jmakry
Good morning
I would like to thank you for your prompt replies.
My issue has been resolved and I thank you for your valuable assistance.
No, I will not need any further assistance.
JeanetteC_Intel
Hello jmakry,
You're welcome. We're dedicated to helping you in any way possible, and I'm pleased to hear your issue has been resolved. I'll proceed to close this thread. If you need assistance in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
