23668 ディスカッション
Intel Arc quantization range error
bronze
初心者
1,857件の閲覧回数
There's a persistent bug I'm encountering with my Intel Arc A380 and A310. With Intel Arc drivers 6876, 6874, and 6790, the quantization range setting, once set to "Full," consistently resets to default after a reboot or system resume. This requires a tedious manual adjustment each time. Interestingly, this specific issue (quantization range reverting to default) does not occur with driver version 6737. The affected driver versions are 6790 through 6876.
0 件の賞賛
4 返答(返信)
DhannielM_Intel
モデレーター
1,763件の閲覧回数
Hello bronze,
Thank you for joining the community. To help us investigate this issue further, I have a few questions:
  • When updating or downgrading the driver, do you select the "Clean Installation" option?
  • Have you used Display Driver Uninstaller (DDU) to perform a clean install or rollback?
  • Have you tried using the latest driver version 32.0.101.6877?
  • Does the issue persist even after restarting the IGS?
Furthermore, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
bronze
初心者
1,750件の閲覧回数
When updating or downgrading drivers, I always perform a clean installation. My method involves booting into safe mode, using DDU (Display Driver Uninstaller) to completely remove the old driver, then disconnecting from the internet and rebooting to install the new one.
Despite installing the latest driver version 32.0.101.6877, the same issue persists: display settings revert from FULL to DEFAULT. This happens automatically after restarting the system or booting up the next day, and I find myself having to manually change it back each time.
Notably, this problem did not occur with the April driver version, gfx_win_101.6737.
DhannielM_Intel
モデレーター
1,713件の閲覧回数
Hello bronze,
Thank you for providing your answers. I will investigate this issue further and update you as soon as possible.
Dhanniel M.
Ernesto_C_Intel1
モデレーター
1,657件の閲覧回数
Hi @bronze
I noticed that you've initially posted your concern on the following thread below: https://community.intel.com/t5/Intel-ARC-Graphics/Intel-Arc-Driver-Quantization-Range-Error/m-p/1694892#M25677
To focus our investigation, I'll close this thread and work with my technician on the original thread that you've created to address the Quantization issue with your graphics card.
Ernesto C.
返信
