23094 Discussions
Intel® Beta Graphics Driver for Skyrim SE* and Fallout 4* for Windows® 10 and Windows 7*/8.1* [15.45]
RonaldM_Intel
This beta driver is provided to improve image quality, while fixing certain graphics issues observed in Fallout 4* and The Elder Scrolls V: Skyrim Special Edition* on Intel graphics devices.
Please check the game studio's system requirements for each title.
A production version driver will follow in a few weeks, if the Beta tests well.
BETA Notice
This driver is being provided as a beta test driver, and while it has had limited validation testing by Intel, it is essentially a test driver and is not to be considered a permanent replacement for a fully validated and certified graphics driver.
  • Use at your own discretion
There is currently a known issue with this Beta driver described as: A blank screen error may be observed when installing the driver. This is only seen when both a DP display, as well as a DP display over USB Type-C are connected. ONLY INSTALL THIS BETA if the issue previously described does not apply to your current configuration, or as a proof of concept.
While Intel may or may not address issues found in this beta version driver, we do welcome feedback particular to the issues listed in the https://downloadmirror.intel.com/26464/eng/ReleaseNotes_GFX_1540.4552.pdf Release Notes that the driver addresses.
  • Please note: this driver is not certified by Microsoft* and will generate a warning when installing.
  • If you receive any installation errors (not including signature warning), delete the current driver completely and without rebooting install this driver to see if this resolves it.
The Windows BETA driver https://downloadcenter.intel.com/download/26464 15.45.12.4552 has been posted to Intel Download Center at the following direct links to the driver:
This exe is for typical install and should be used by normal users.
https://downloadmirror.intel.com/26464/eng/win64_154512.4552.exe https://downloadmirror.intel.com/26464/eng/win64_154512.4552.exe
This zip format is intended for developers and IT professionals.
https://downloadmirror.intel.com/26464/eng/win64_154512.4552.zip https://downloadmirror.intel.com/26464/eng/win64_154512.4552.zip
<table border="1" class="jiveBorder tablesorter tablesorter-default" height="200" jive-data-cell="{"color":"# 000000","textAlign":"left","padding":"2"}" jive-data-header="{"color":"# FFFFFF","backgroundColor":"# 6690BC","textAlign":"center","padding":"2","fontFamily":"intel-clear,arial,helvetica,helvetica neue,verdana,sans-serif","verticalAlign":"baseline"}" style="border: 1px solid # 000000; fon...
