23526 Discussions
Intel Core i7-14700K problem UHD Graphics 770
vitamin2024
A completely new computer was assembled on an Intel Core i7-14700K processor with built-in UHD Graphics 770. Asus Z790-PRO motherboard. First connection via Displayport from the motherboard to the monitor. (Windows is not installed.) From time to time, stripes appear in the bios (artifacts). Is this a processor defect? what could be the problem?
n_scott_pearson
This can be a problem with the memory, or with the motherboard, or with motherboard's BIOS' memory training/initialization.
Hope this helps,
vitamin2024
Thanks for helping. I'll try to take another memory for testing.
RandyT_Intel
Hello vitamin2024,
I wanted to check in and see if the issue you were experiencing has been resolved. If you still need assistance from our end, could you please answer the following questions? This will help me determine how I can further support you:
  1. Have you updated the BIOS?
  2. Have you tried a different cable or port?
  3. Is the processor or GPU overheating?
  4. Have you tested with a different monitor?
  5. Are there any visible physical damages? Please inspect the motherboard and processor for any signs of physical damage or improper seating.
I look forward to your response so we can assist you further.
Randy T.
vitamin2024
The problem was found in the service center. Defective motherboard asus x790 pro. Answer to your question.
1. Yes.
2. Yes.
3. No, t 60 degrees Celsius.
4. Yes.
5. no visible damage on the processor or on the motherboard.
RandyT_Intel
Hello vitamin2024,
Thank you for your update. Since we have identified that the motherboard is the main issue, I will now proceed to close this ticket.
If you have any questions, inquiries, or concerns in the future, please feel free to create a new ticket. We are always here to assist you.
Thank you for your cooperation.
Randy T.
