23801 Discussions
Intel Display Driver problem
AAndr55
Hello
For the past few weeks I have been experiencing some problems with the display driver. I was playing on my laptop and I noticed the game started to lag quite badly, which it has never done before and wasn't supposed to do. Then I got an error saying that Intel display driver had a problem but it has recovered. But, when I opened the game again, the lag was still there. I restarted the laptop, turned it on and off again, same thing would always happen, I would open the game, play for a bit, then massive lag. However, I never got the error again, just the lag. I uninstalled the Intel driver, the nvidia driver, reinstalled them, updated them, still nothing. I am currently running the latest updates for both drivers, the lag is still there. It doesn't happen all the time, though. Some days it works, some days it doesn't.
I have an Asus ROG, with Intel i7-6700 HQ @ 2.60 Gh, nvidia geforce gtx 950M, 24 GB DDR4 RAM and I am running Windows 10 64 bit. The laptop is new, I got it two months ago, so I doubt it is a hardware problem, and with these specs, I should have absolutely no problem running The Sims 4 or older games, like Assassin's Creed Revelations, but I still do.
Any possible fix for this?
Hello Andreea:
The processor that the PC is using works with Intel® HD Graphics 530, the driver version 4501 is the latest one available for that graphics controller, please try to install it manually:
Instructions to install the driver manually for Windows® 10:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Driver 4501:
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
What is the specific model of the ASUS ROG?
Did you try the graphics driver provided by ASUS? You can get it from the following link:
https://www.asus.com/Notebooks/X551MA/HelpDesk_Download/ https://www.asus.com/Notebooks/X551MA/HelpDesk_Download/
Also, you can try to use the Microsoft drivers, you can do that by uninstalling the current driver and trying a Windows update.
Please let me know the results if trying the steps above.
Alberto
AAndr55
I did all of the above before posting here, and neither worked, unfortunately. My last option was reinstalling the Windows, which I did, and everything seems to work just fine so far. I assume I will see in a few days if the problem is still there. Anyway, thank you for your answer, Alberto.
Hello Andreea:
Thank you very much for that information.
Yes, when the rest of the troubleshoot steps do not work, then the last option left to try will be to reinstall Windows as you did, hopefully there will be no more problems with the laptop. And it should work properly now.
Alberto
AAndr55
Hello, Alberto.
It seems like my problem isn't solved yet. All was well for three days, but now the lag is back. My ROG model is GL552V, if that helps with anything. I have ran out of things to try to make this work. Any other options I may have?
Hello Andreea:
Thank you very much for that information, at this point pretty much you tried all the troubleshoot steps that we recommend.
Based on the fact that the Nvidia and Intel drivers did not work, we can try the driver from ASUS directly, it is called VGA:
https://www.asus.com/ROG-Republic-Of-Gamers/ROG-GL552VW/HelpDesk_Download/ https://www.asus.com/ROG-Republic-Of-Gamers/ROG-GL552VW/HelpDesk_Download/
When you install Windows there is a graphics driver that gets installed, that is a Microsoft driver, not sure if that is the driver you are using now, but if it is not, you can try to use that one, without installing the Intel driver to verify if that fixes the problem.
Another option will be to get in contact ASUS directly for further assistance, since they are the manufacturer of the laptop.
The next thing for us to do at this point will be to try to replicate the issue, and for that we need the following information:
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issuePlease place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</span>Hardware (HW)Brand and Model of the system.Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?Make and model of any Displays that are used to see the issue (see note2 below).  LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)How much memory [RAM] in the system (see note2 below).<span style="border: none windowtext 1.0pt; padding: 0in; color: #...
AAndr55
The ASUS driver doesn't work, neither does the Microsoft one. I have tried both of them before. You have here the two files you requested and the information you need.
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issuePlease place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>Always (100%): X
Often (51-99%):
Sporadic (20-50%):
ie Does it have AMD or NV graphics too?nVidia 950MMake and model of any Displays that are used to see the issue (see note2 below).  LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)LFPHow much memory [RAM] in the system (see note2 below).24 GB, DDR4Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc<td style="padding: 0 5.4pt; border-top: none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; border-left: none; font-style: inherit;"...
Hello Andreea:
Thank you very much for providing all that information.
Now we will try to replicate the issue, using the closest configuration based on the components you are using, we will do that with the game Sims 4, in order to try to find out a possible fix for this problem.
As soon as I get any results, I will post all the details on this thread.
Did you try a BIOS update to the very latest version? You will find the file for latest BIOS version on the following link, it is version 218:
Please let me know the results of trying the BIOS update or if that is the version that is currently installed on the laptop.
Alberto
AAndr55
Hello, Alberto. That is not the correct BIOS update, it's for GL552VW, and I have GL552VX. The latest version is 204 and I have 203. I will update it though and let you know if that solves my issue.
Hello Andreea:
Perfect, thank you very much for letting us know the correct BIOS version.
Please let us know the results of trying that version.
Alberto
AAndr55
Hello, Alberto. I updated my BIOS to version 204 and the problem is still there.
Hello Andreea:
We will start the investigation on this matter, in order to try to find a possible solution for this problem.
As soon as I get any updates, I will post all the details on this thread.
Alberto
AAndr55
Hello, Alberto. I tried both of those drivers and they didn't fix my problem. However, nvidia released a new driver update, for the version 373.06. Should I update it, or should I wait?
Hello Andreea:
Yes, please try that Nvidia driver as well and let us know the results.
Alberto
AAndr55
I updated the nvidia driver and everything seems to work fine for now, but as before, I assume I will see in a few days. Thank you for your help, Alberto.
AAndr55
Well, looks like it didn't solve the problem after all.
Hello Andreea:
We are sorry to hear that the problem still persists.
Now, we will continue with our investigation in order to find a possible fix for this issue.
Alberto
Hello Andreea:
I just wanted to let you know that we are still currently working on this matter in order to try to find a possible resolution for this problem.
In this case, as you mentioned before, the laptop that you are using has two different types of graphics controllers, it has the Intel® graphics and the Nvidia graphics controllers.
So, I will attach a document where you will see some steps to do, in order to try to identify under which graphics controller the problem occurs.
Please try the steps on that document and let us know the results.
Alberto
Hello Andreea:
I just wanted to check if you were able to do the steps from the document provided above, and if the problem with the games was resolved or if it still persists?
Alberto
AAndr55
Hello, Alberto.
I waited this long to reply because lately I haven't had any issues with my laptop, and given the history of how it would work for a few days, I wanted to wait before telling you everything was fine. But, right now, I think my issue is solved. I don't know why, but it just stopped and everything works as it should. Thank you for all the help you provided.
