23848 Discussions
Intel Driver And Support Assistant Problem While Launching second time
LAVITEN
I want To Ask this Intel® Driver & Support Assistant When I install It First time when I scan It It Shows All The Driver To Update But When I launch It For The Second Time It Shows That Sorry, something went wrong while trying to scan. I reinstalled It But It's Showing The Same Thing again and again
AlHill
You can try clearing your browser cache.
If that does not work, uninstall IDSA using this tool:
https://downloadcenter.intel.com/download/29608/Intel-Driver-Support-Assistant-Uninstaller?v=t
Then, reinstall IDSA.
AlHill
LAVITEN
Thank You I will Try It And Tell You If It Works Or Not
LAVITEN
It's Sorry To Tell You That It Doesn't Works I Cleaned The Cache to 400 mb then I uninstalled It With The Software That You Gave Me Then I re-installed it but it loaded for the first time second time it says
AlHill
I hate to ask, but did you restart the machine after the uninstall?
LAVITEN
Yes I Restarted It It dosen't works
LAVITEN
Thank You I Tried To Do It Again And It's Working Now Everytime I launch It Thank you So Much
