23784 Discussions
Intel Driver Support Assistant + DSA Error
Kato94
I'm running Windows 11 and recently got a new update through windows update. After this update IDSA stopped working and comes with "The application was unable to start correctly (0xc0000135)". Even the DSA official uninstaller comes up with the same error when trying to launch it.
Please release a new update or give me a fix as this really screwing my laptop.
Kato94
Thank you getting back to me.
I have fixed the issue by reinstalling the .net framework by checking and unchecking in the windows services.
Steven_Intel
Hello Kato94,
It seems that is an error with the latest Windows 11 update, which has affected multiple applications, not only Intel® Driver & Support Assistant. By any chance, have you tried contacting Microsoft support about this?
In the meantime, I can help you to install the latest updates for your system directly from our Download Center. If you would like that, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Kato94
Steven_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
If you need any additional information, please submit a new question, as this thread will no longer be monitored. Thank you for your understanding.
Steven G.
