23704 Discussions
Intel Driver Update Utility vs Windows Update
CChan91
I am using HP dv6-7038tx, which has Intel HD 4000 inside.
Whenever I checked update with Intel Driver Update Utility, I found a newer version (15.33.38.64.4252)
However, after I installed that version, Windows Update will download and install the version (10.18.10.4276) every time.
Should I disable Windows Update so that it stops downloading older version?
Amy_C_Intel
Hello chanyam,
If you want to keep the version that the Intel® Driver Update Utility is giving you, I would recommend to disable Windows Updates.
For further reference visit;
http://windows.microsoft.com/en-us/windows/turn-automatic-updating-on-off# turn-automatic-updating-on-off=windows-7 Turn automatic updating on or off - Windows Help
http://www.howtogeek.com/224471/how-to-prevent-windows-10-from-automatically-downloading-updates/ How to Prevent Windows 10 From Automatically Downloading Updates
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
