23832 Discussions
Intel GMA 950 on chispet Mobile Intel(R) 945 Express Chipset Family
I recently installed newer version of the driver 8.15.10.1930 for GMA 950 and it seems to be quite unstable. Formerly I could produce only 1360 x 786
but it keeps changing the resolution and also the resolution values I can choose on Windows 7 x64 feature to set the screen resolution.
and now it is so
this occurred after a stand-by procedure
DArce
Valued Contributor III
Please be aware that we provide generic drivers that have not been developed or tested specially for your system. Each motherboard, laptop or Original Equipment Manufacturer can add, remove and change features on the video controllers they implement on their systems. Therefore they provide customized drivers to support such changes. So we always recommend using the latest drivers provided directly by your motherboard or Original Equipment Manufacturer.
From our side, we have not seen any similar issue since the driver was posted back in 2009. Possibly there might be a problem when using such generic driver instead of the customized one.
In this case, we suggest using the latest driver that was provided by your laptop manufacturer and check if the problem persists.
I have an old laptop HP 530 and it was strange to see such resolutions I never seen them before it just happened after installed last version of the driver on Windows 7 x64 bit sp1.
It happened during normal work and just after a restart it was fixed.
I just made a small C# App that using System.Management and few lines of code and it returns this
BitsPerPel = 32
Caption = Mobile Intel(R) 945 Express Chipset Family
Description = Mobile Intel(R) 945 Express Chipset Family
DeviceName = Mobile Intel(R) 945 Express Chipset Family
DisplayFlags = 0
DisplayFrequency = 60
DitherType =
DriverVersion =
ICMIntent =
ICMMethod =
LogPixels = 96
PelsHeight = 768
PelsWidth = 1024
SettingID = Mobile Intel(R) 945 Express Chipset Family
SpecificationVersion = 1025
caption=320 x 200 x 256 colors @ 70 Hertz, description=320 x 200 x 256 colors @ 70 Hertz resolution=320x200 colors=256 refresh rate=|70| scan mode=4
caption=320 x 200 x 65536 colors @ 70 Hertz, description=320 x 200 x 65536 colors @ 70 Hertz resolution=320x200 colors=65536 refresh rate=|70| scan mode=4
caption=320 x 200 x 4294967296 colors @ 70 Hertz, description=320 x 200 x 4294967296 colors @ 70 Hertz resolution=320x200 colors=4294967296 refresh rate=|70| scan mode=4
caption=320 x 240 x 256 colors @ 70 Hertz, description=320 x 240 x 256 colors @ 70 Hertz resolution=320x240 colors=256 refresh rate=|70| scan mode=4
caption=320 x 240 x 65536 colors @ 70 Hertz, description=320 x 240 x 65536 colors @ 70 Hertz resolution=320x240 colors=65536 refresh rate=|70| scan mode=4
caption=320 x 240 x 4294967296 colors @ 70 Hertz, description=320 x 240 x 4294967296 colors @ 70 Hertz resolution=320x240 colors=4294967296 refresh rate=|70| scan mode=4
caption=400 x 300 x 256 colors @ 70 Hertz, description=400 x 300 x 256 colors @ 70 Hertz resolution=400x300 colors=256 refresh rate=|70| scan mode=4
caption=400 x 300 x 65536 colors @ 70 Hertz, description=400 x 300 x 65536 colors @ 70 Hertz resolution=400x300 colors=65536 refresh rate=|70| scan mode=4
caption=400 x 300 x 4294967296 colors @ 70 Hertz, description=400 x 300 x 4294967296 colors @ 70 Hertz resolution=400x300 colors=4294967296 refresh rate=|70| scan mode=4
caption=512 x 384 x 256 colors @ 70 Hertz, description=512 x 384 x 256 colors @ 70 Hertz resolution=512x384 colors=256 refresh rate=|70| scan mode=4
caption=512 x 384 x 65536 colors @ 70 Hertz, description=512 x 384 x 65536 colors @ 70 Hertz resolution=512x384 colors=65536 refresh rate=|70| scan mode=4
caption=512 x 384 x 4294967296 colors @ 70 Hertz, description=512 x 384 x 4294967296 colors @ 70 Hertz resolution=512x384 colors=4294967296 refresh rate=|70| scan mode=4
caption=640 x 400 x 256 colors @ 70 Hertz, description=640 x 400 x 256 colors @ 70 Hertz resolution=640x400 colors=256 refresh rate=|70| scan mode=4
caption=640 x 400 x 65536 colors @ 70 Hertz, description=640 x 400 x 65536 colors @ 70 Hertz resolution=640x400 colors=65536 refresh rate=|70| scan mode=4
caption=640 x 400 x 4294967296 colors @ 70 Hertz, description=640 x 400 x 4294967296 colors @ 70 Hertz resolution=640x400 colors=4294967296 refresh rate=|70| scan mode=4
caption=640 x 480 x 256 colors @ 59 Hertz, description=640 x 480 x 256 colors @ 59 Hertz resolution=640x480 colors=256 refresh rate=|59| scan mode=4
caption=640 x 480 x 256 colors @ 70 Hertz, description=640 x 480 x 256 colors @ 70 Hertz resolution=640x480 colors=256 refresh rate=|70| scan mode=4
caption=640 x 480 x 256 colors @ 72 Hertz, description=640 x 480 x 256 colors @ 72 Hertz resolution=640x480 colors=256 refresh rate=|72| scan mode=4
caption=640 x 480 x 256 colors @ 75 Hertz, description=640 x 480 x 256 colors @ 75 Hertz resolution=640x480 colors=256 refresh rate=|75| scan mode=4
caption=640 x 480 x 256 colors @ 85 Hertz, description=640 x 480 x 256 colors @ 85 Hertz resolution=640x480 colors=256 refresh rate=|85| scan mode=4
caption=640 x 480 x 256 colors @ 99 Hertz, description=640 x 480 x 256 colors @ 99 Hertz resolution=640x480 colors=256 refresh rate=|99| scan mode=4
caption=640 x 480 x 256 colors @ 119 Hertz, description=640 x 480 x 256 colors @ 119 Hertz resolution=640x480 colors=256 refresh rate=|119| scan mode=4
caption=640 x 480 x 65536 colors @ 59 Hertz, description=640 x 480 x 65536 colors @ 59 Hertz resolution=640x480 colors=65536 refresh rate=|59| scan mode=4
caption=640 x 480 x 65536 colors @ 70 Hertz, description=640 x 480 x 65536 colors @ 70 Hertz resolution=640x480 colors=65536 refresh rate=|70| scan mode=4
caption=640 x 480 x 65536 colors @ 72 Hertz, description=640 x 480 x 65536 colors @ 72 Hertz resolution=640x480 colors=65536 refresh rate=|72| scan mode=4
caption=640 x 480 x 65536 colors @ 75 Hertz, description=640 x 480 x 65536 colors @ 75 Hertz resolution=640x480 colors=65536 refresh rate=|75| scan mode=4
caption=640 x 480 x 65536 colors @ 85 Hertz, description=640 x 480 x 65536 colors @ 85 Hertz resolution=640x480 colors=65536 refresh rate=|85| scan mode=4
caption=640 x 480 x 65536 colors @ 99 Hertz, description=640 x 480 x 65536 colors @ 99 Hertz resolution=640x480 colors=65536 refresh rate=|99| scan mode=4
caption=640 x 480 x 65536 colors @ 119 Hertz, description=640 x 480 x 65536 colors @ 119 Hertz resolution=640x480 colors=65536 refresh rate=|119| scan mode=4
caption=640 x 480 x 4294967296 colors @ 59 Hertz, description=640 x 480 x 4294967296 colors @ 59 Hertz resolution=640x480 colors=4294967296 refresh rate=|59| scan mode=4
caption=640 x 480 x 4294967296 colors @ 70 Hertz, description=640 x 480 x 4294967296 colors @ 70 Hertz resolution=640x480 colors=4294967296 refresh rate=|70| scan mode=4
caption=640 x 480 x 4294967296 colors @ 72 Hertz, description=640 x 480 x 4294967296 colors @ 72 Hertz resolution=640x480 colors=4294967296 refresh rate=|72| scan mode=4
caption=640 x 480 x 4294967296 colors @ 75 Hertz, description=640 x 480 x 4294967296 colors @ 75 Hertz resolution=640x480 colors=4294967296 refresh rate=|75| scan mode=4
caption=640 x 480 x 4294967296 colors @ 85 Hertz, description=640 x 480 x 4294967296 colors @ 85 Hertz resolution=640x480 colors=4294967296 refresh rate=|85| scan mode=4
caption=640 x 480 x 4294967296 colors @ 99 Hertz, description=640 x 480 x 4294967296 colors @ 99 Hertz resolution=640x480 colors=4294967296 refresh rate=|99| scan mode=4
caption=640 x 480 x 4294967296 colors @ 119 Hertz, description=640 x 480 x 4294967296 colors @ 119 Hertz resolution=640x480 colors=4294967296 refresh rate=|119| scan mode=4
caption=800 x 600 x 256 colors @ 60 Hertz, description=800 x 600 x 256 colors @ 60 Hertz resolution=800x600 colors=256 refresh rate=|60| scan mode=4
caption=800 x 600 x 256 colors @ 72 Hertz, description=800 x 600 x 256 colors @ 72 Hertz resolution=800x600 colors=256 refresh rate=|72| scan mode=4
caption=800 x 600 x 256 colors @ 75 Hertz, description=800 x 600 x 256 colors @ 75 Hertz resolution=800x600 colors=256 refresh rate=|75| scan mode=4
caption=800 x 600 x 256 colors @ 85 Hertz, description=800 x 600 x 256 colors @ 85 Hertz resolution=800x600 colors=256 refresh rate=|85| scan mode=4
caption=800 x 600 x 256 colors @ 99 Hertz, description=800 x 600 x 256 colors @ 99 Hertz resolution=800x600 colors=256 refresh rate=|99| scan mode=4
caption=800 x 600 x 256 colors @ 119 Hertz, description=800 x 600 x 256 colors @ 119 Hertz resolution=800x600 colors=256 refresh rate=|119| scan mode=4
caption=800 x 600 x 65536 colors @ 60 Hertz, description=800 x 600 x 65536 colors @ 60 Hertz resolution=800x600 colors=65536 refresh rate=|60| scan mode=4
caption=800 x 600 x 65536 colors @ 72 Hertz, description=800 x 600 x 65536 colors @ 72 Hertz resolution=800x600 colors=65536 refresh rate=|72| scan mode=4
caption=800 x 600 x 65536 colors @ 75 Hertz, description=800 x 600 x 65536 colors @ 75 Hertz resolution=800x600 colors=65536 refresh rate=|75| scan mode=4
caption=800 x 600 x 65536 colors @ 85 Hertz, description=800 x 600 x 65536 colors @ 85 Hertz resolution=800x600 colors=65536 refresh rate=|85| scan mode=4
caption=800 x 600 x 65536 colors @ 99 Hertz, description=800 x 600 x 65536 colors @ 99 Hertz resolution=800x600 colors=65536 refresh rate=|99| scan mode=4
caption=800 x 600 x 65536 colors @ 119 Hertz, description=800 x 600 x 65536 colors @ 119 Hertz resolution=800x600 colors=65536 refresh rate=|119| scan mode=4
caption=800 x 600 x 4294967296 colors @ 60 H...
And now this is the output of my program that retrieves data from computer using System.Management. I got this after playing a bit with resolution of the screen.
BitsPerPel = 32
DisplayFlags = 0
DitherType =
DriverVersion =
ICMIntent =
ICMMethod =
LogPixels = 96
PelsHeight = 768
PelsWidth = 1024
Current resolution on primary screen: 1280 x 1024
\\.\DISPLAY1
caption=800 x 600 x 4294967296 colors @ 60 Hertz, description=800 x 600 x 4294967296 colors @ 60 Hertz resolution=800x600 colors=4294967296 refresh rate=|60| scan mode=4
caption=800 x 600 x 4294967296 colors @ 72 Hertz, description=800 x 600 x 4294967296 colors @ 72 Hertz resolution=800x600 colors=4294967296 refresh rate=|72| scan mode=4
caption=800 x 600 x 4294967296 colors @ 75 Hertz, description=800 x 600 x 4294967296 colors @ 75 Hertz resolution=800x600 colors=4294967296 refresh rate=|75| scan mode=4
caption=1024 x 768 x 256 colors @ 60 Hertz, description=1024 x 768 x 256 colors @ 60 Hertz resolution=1024x768 colors=256 refresh rate=|60| scan mode=4
caption=1024 x 768 x 256 colors @ 70 Hertz, description=1024 x 768 x 256 colors @ 70 Hertz resolution=1024x768 colors=256 refresh rate=|70| scan mode=4
caption=1024 x 768 x 256 colors @ 75 Hertz, description=1024 x 768 x 256 colors @ 75 Hertz resolution=1024x768 colors=256 refresh rate=|75| scan mode=4
caption=1024 x 768 x 65536 colors @ 60 Hertz, description=1024 x 768 x 65536 colors @ 60 Hertz resolution=1024x768 colors=65536 refresh rate=|60| scan mode=4
caption=1024 x 768 x 65536 colors @ 70 Hertz, description=1024 x 768 x 65536 colors @ 70 Hertz resolution=1024x768 colors=65536 refresh rate=|70| scan mode=4
caption=1024 x 768 x 65536 colors @ 75 Hertz, description=1024 x 768 x 65536 colors @ 75 Hertz resolution=1024x768 colors=65536 refresh rate=|75| scan mode=4
caption=1024 x 768 x 4294967296 colors @ 60 Hertz, description=1024 x 768 x 4294967296 colors @ 60 Hertz resolution=1024x768 colors=4294967296 refresh rate=|60| scan mode=4
caption=1024 x 768 x 4294967296 colors @ 70 Hertz, description=1024 x 768 x 4294967296 colors @ 70 Hertz resolution=1024x768 colors=4294967296 refresh rate=|70| scan mode=4
caption=1024 x 768 x 4294967296 colors @ 75 Hertz, description=1024 x 768 x 4294967296 colors @ 75 Hertz resolution=1024x768 colors=4294967296 refresh rate=|75| scan mode=4
caption=1152 x 864 x 256 colors @ 60 Hertz, description=1152 x 864 x 256 colors @ 60 Hertz resolution=1152x864 colors=256 refresh rate=|60| scan mode=4
caption=1152 x 864 x 256 colors @ 75 Hertz, description=1152 x 864 x 256 colors @ 75 Hertz resolution=1152x864 colors=256 refresh rat...
