23834 Discussions
Intel GMA HD. OpenGL driver problem. Extension GL_ARB_draw_instanced fails to use
Hello!
I would like to get advising to use extension GL_ARB_draw_instanced.
The driver reported the presence of this extension, but to work with this extension, you must have EXT_gpu_shader4 or NV_vertex_program4 or OpenGL 3.0.
http://www.opengl.org/registry/specs/ARB/draw_instanced.txt http://www.opengl.org/registry/specs/ARB/draw_instanced.txt
In the current version of the driver does not support EXT_gpu_shader4 or NV_vertex_program4 or OpenGL 3.0.
How is it possible use a "Instanced" without such a gl_InstanceID?
Attachment graphics diagnostic report:
Intel® HD Graphics (Core i5)
Report Date: 2/9/2011
Report Time[hr:mm:ss]: 19:13:15
Driver Version: 6.14.10.5313
Operating System: Windows XP Professional Service Pack 2(5.1.2600)
Default Language: English (United States)
DirectX* Version: 9.0
Physical Memory: 1909 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 256 MB
Graphics Memory in Use: 35 MB
Processor: x86 Family 6 Model 37 Stepping 5
Processor Speed: 2393 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2077.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Display Type: Analog
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 20.08 inches
Vertical: 11.42 inches
Monitor Supported Modes:
640 by 480 (67 Hz)
640 by 480 (75 Hz)
640 by 480 (72 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 720 (60 Hz)
1280 by 800 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 1024 (60 Hz)
1360 by 765 (60 Hz)
1440 by 900 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 04 72 C8 00 BA A6 40 01
0E 14 01 03 68 33 1D 78 CA EE 95 A3 54 4C 99 26
0F 50 54 BF EF 80 71 4F 81 80 81 C0 81 00 8B C0
95 00 B3 00 D1 C0 02 3A 80 18 71 38 2D 40 58 2C
45 00 FE 1F 11 00 00 1E 00 00 00 FD 00 38 4C 1F
53 11 00 0A 20 20 20 20 20 20 00 00 00 FC 00 56
32 33 33 48 0A 20 20 20 20 20 20 20 00 00 00 FF
00 4C 47 51 30 44 30 32 39 38 35 31 33 0A 00 44
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Chrontel
Device ID: 66
Device Revision: 2
Major Version: 1
Minor Version: 1
* Other names and brands are the property of their respective owners. *
