23102 Discussions
Intel Graphic 4000 fails on Windows 10 1809 update Error 48
MJehl
Hi
Is there in the mean time a solution ready for that update? I tried all as I have found in the forum here but still get the Error 48!
Any suggestions welcome
Stefan3D
Full Error Message
The software for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48)
Recommended Resolution
Contact the manufacturer of your hardware device to obtain the latest version or the updated driver. Then, install it on your computer.
Source: https://support.microsoft.com/en-us/help/310123/error-codes-in-device-manager-in-windows
MJehl
Vendor of the device is: Intel - NUC DC53427HYE! 🙂
I tried the last updated driver from the Intel page! No possibility to solve the problem...
Stefan3D
MJehl
Already tried - fails!
But finally I do not understand the reason who and why it is blocking…
Finally it can't be the solution updating a device only based on such a reason - because it is pressure to customers to update from Microsoft and Intel 🙂
Windows is not possible to stay on earlier versions or blocking to update to newer versions!
n_scott_pearson
Your NUC is from 2013 and was long ago discontinued. No effort is being put into adding features (such as new Windows O/S versions) for discontinued boards/kits. The last supported Windows version on this NUC is (and will remain) Windows 8.1. If you are using Windows 10, then you are on your own; it isn't supported.
Sorry, but this is reality.
