I have the following graphics chipset and having searched the itel resource can only find a solution for the Q4* chipsets not the Q35
Chipset
Detected Chipset:
Intel(R) Q35 Express Chipset
Chipset Components
Memory Controller:
Intel(R) 82Q35 Memory Controller Hub
I/O Controller:
Intel(R) 82801IO Intel(R) I/O Controller Hub (ICH9DO) SATA Controller found in IDE mode
Integrated Graphics:
This chipset supports integrated graphics.
there is detail here of a solution but does not provide a link for the Q35 chipset
http://www.intel.com/support/graphics/sb/cs-028366.htm http://www.intel.com/support/graphics/sb/cs-028366.htm
all links go to the same page - here:
http://www.intel.com/support/graphics/sb/CS-030332.htm http://www.intel.com/support/graphics/sb/CS-030332.htm
can anyone advise if I can undate the graphics driver to support an HP Compaq LA1905wg monitor with optimal resolution at 1440x900
on windows xp pro
many thanks
Andrew
I have found alternative post on the same subject and tried their solution but to no avail!
This post (/message/90511 http://communities.intel.com/message/90511) indentifies a driver download for Q35 chipset located here http://www.intel.com/support/graphics/sb/cs-029955.htm http://www.intel.com/support/graphics/sb/cs-029955.htm.
I downloaded and when I try and install see error message:
The driver being installed is not valid for this computer. Please obtain the appropriate driver from the computer's manufacturer. Setup will Exit.
Can any one direct me to the correct file download to update the driver?
Windows XP professional - v2002 SP3
regards
Andrew
