23806 Discussions
Intel® Graphics Command Center
JefDC
My computer is connected to a 4K tv used as monitor.
The max selectable resolution in Windows 11 is 1080p
The Intel® Graphics Command Center does show all te resolutions up to 4K but I cannot access them in the Command Center.
Can you help ?
Best regards
Jef
IsaacQ_Intel
Hello @JefDC
After updating to the latest Intel Graphics command Center Version 1.100.4979.0 the resolution setting option is missing.
Resolution
The latest version of IGCC no longer contains this setting.
Use Windows* Display Settings to change the resolution.
Select Start > Settings > System > Display.
Isaac Q.
IsaacQ_Intel
Hello JefDC
We hope you are doing fine.
Isaac Q.
IsaacQ_Intel
Hello JefDC
Best regards.
Isaac Q.
JefDC
Thanks for the reply, but as  the resolution setting option  is missing and the Windows Display Settings don't offer the 4K resolution I'm stuck on 1080p.
I use a Microsoft Surface 6 which does have the 4K ability (and does so on my monitor connected via the docking station) but apparently not via a MiniDP to HDMI cable to the 4K tv.
Best regards
Jef
