23851 Discussions
Intel Graphics Command Center
janloid77
Is it safe to uninstall IGCC? I have a dedicated GPU, and want to lower the RAM usage. If not, is it okay to just disable/end task in the task bar?
RobbieR_Intel
Hello janloid77,
Thank you for reaching out. Yes, it's generally safe to uninstall Intel Graphics Command Center (IGCC) if you're only using your dedicated GPU. It mainly manages settings for Intel's Integrated Graphics, so you shouldn't face any issues by removing it.
Alternatively, if you'd prefer to keep it but reduce RAM usage, you can disable it from starting up automatically or simply end the task in the taskbar.
We look forward for your reply!
Robbie R.
janloid77
I uninstalled it. It doesn't seem to be consuming much RAM since there's no much change. Thanks for helping!
RobbieR_Intel
Hello janloid77,
Robbie R.
RobbieR_Intel
Hello janloid77,
Thank you for keeping us updated. I'm glad that the issue has been resolved.
Since the issue is now fixed, I will now close this inquiry.
Robbie R.
